Hello,
I bought a Canon Legria HF G10 and was thinking of buying a filter only for lens protection. Is there any inconvenient in doing so? Can the image quality be affected by the application of such a filter? Can you give me some tips concerning what type of filter to buy if in fact I should buy one?
Thank you very much.
Nuno
it's a good idea to get an ultra clear for shooting indoors, and a uv filter for outdoor daylight.
As soon as I bought my JVC camcorder, I got a clear glass and stuck that over the lens. Then no worries about dust or scratches on the regular lens. Camcorder lens are sometimes small, but you can usually find filters online. Try Amazon or Ebay. Your camera manual should tell you the size.
You might also look into a UV filter and a circular polarizer filter. It's great for increasing the contrast of clouds and skies. One possible downside of adding anything to your lens is vignetting if the glass sticks out too far. But not likely unless you stack filters or add a lens hood and it usually only shows at wide angle settings.
EDIT: Here's an example from the UK: http://www.digitaltoyshop.co.uk/THREE_PIECES_FILTER_KIT_Canon_LEGRIA_HF_G10_t2317_132
Time for an HD cam.. Last cam was Pana. DVC80.. Next will be?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 25th Nov 2011, 19:35 -
Lens Help?
By MurbeckJackson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 30th Jan 2011, 17:41 -
best DVD recorder filter & ATI AIW filter
By VCRcomp in forum RestorationReplies: 1Last Post: 27th Jan 2011, 18:27 -
How to increase when TC OR CAM DVD to Tc or Cam rip
By antonymaheshca in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2010, 14:42 -
HD Cam wrote .mts files to my flash card but put in another cam still mts
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Dec 2009, 07:15
