If the elementary stream is corrupted or broken, it's natural that the muxing applications will reject it.
BTW, how did you obtain the problematic .264 video --- did you encode it, or did you demux it from another file? -
I am converting multiple VOB files like this:
Step 1:
Step 2:ffmpeg -i VTS_01_4.vob -c:v libx264 -c:a aac -strict experimental VTS_01_4.mp4
Create a text file and include the paths and names of each file to concatenate (or "join"). Example file,
input.txt:
Step 3.file '/home/jenia/input1.mp4'
file '/home/jenia/input2.mp4'
file '/home/jenia/input3.mp4'
Now you can use concat
Step 4.ffmpeg -f concat -i input.txt -codec copy output.mp4
Deinterlace
HTML Code:ffmpeg -i input.mp4 -vf "yadif=0:-1:0, scale=trunc(iw/2)*2:trunc(ih/2)*2" -strict -2 output.mp4
So all i need to do is swap out the aac audio, any ideas on what I have done wrong? -
why not convert them with mencoder which can load specific titles from a DVD or if for some unknown reason ffmpeg needs to be used use the 'contant-textfile-'trick directly with the vob files
(also the whole reencoding and after reencoding reencode again to deinterlace seems like a huge mistake if quality is of any concern,...) -
you can email the source file to me, elycssoft@gmail.com,
I am a coder, I like coding, www.elycs.com
how can i mux to mp4 from h264/aac using ffmpeg
By DKhanh in forum Video ConversionReplies: 3Last Post: 24th Aug 2013, 12:50 -
Problems with ffmpeg/mencoder burning subtitles to a mp4 file [h264 aac]
By landuchi in forum Video ConversionReplies: 0Last Post: 1st Oct 2012, 12:57 -
mux h264/aac flv into h264/aac mkv
By Pitorasilo in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2011, 10:36 -
MKVtoolnix muxing with h264 and aac
By lovepopp in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2009, 03:23 -
H264/AC3 (MKV) to H264/AAC (MP4) ?
By jccca in forum Video ConversionReplies: 10Last Post: 13th Dec 2008, 20:06
