I still have a dvd player in the house and i have always sought my backups to be in dvd format on a dvdr disc, i am curious to know whether the dvd player can play a blu ray quality-ish file from dvdr in x264 formatted to fill the dvdr ?..so i could have my blurays in this format on a dvdr for the kids to play in the bedroom..for example..
Video ....: 1280x536 (X264 @ 23.976fps)720p.BluRay.X264
Results 1 to 12 of 12
No. Even if they upscale, DVD players will only accept SD video as a source (whether from a DVD-Video disc or a file). This is generally up to around 720x576 (PAL) or 720x480 (NTSC).
And no DVD player accepts h.264-encoded video, that I'm aware of.If cameras add ten pounds, why would people want to eat them? -
if it's an HDTV then there is a chance it might play it by itself off of a usb drive. if it's not an HDTV then of course it won't play anything greater than SD 480.
But would it be better than a normal dvd given that the actual video file wasnt compressed on the dvdr by removing subs, extras etc etc ?
Its just that i saw in various places lots of bluray type files that all happened to be 4.34gb to fit on a dvdr, i understand that maybe this is for the purpose of backing up blurays cheaply but i dont see why anyone would do this because surely to get bluray video to fit on dvdr there would be quite a considerable ammount of compression ?? which brings me full circle to my question..is a converted/compressed bluray made to fit on a dvdr going to be better than a non compressed dvd9 video file to dvdr ? -
I doubt it, given that most good DVDs are made from a higher-def source than yours, and that you downloaded something that someone else had already reencoded from a Blu-Ray source. It could be pretty good, though, after AvsToDVD gets done with it.
im aware of file size vs quality, i used to rencode dvd9 to dvdr back in the day using CCE but where possible would remove as much as possible to keep the actual film unencoded so i am no stranger to doing it.
I get BD25 discs at around £0.80 each, is it possible to do the same with bluray as it was with dvd9, ie, compress it to fit on the BD25 and also remove all the foereign audio and other unwanted stuff but leep the menu and chapters etc ? i have one bluray player in the house and ps3 and xbox 360..is it possible to do it in such a way that it would play on all three devices ??is there a guide on this vast forum/website that would instruct me how to go about it ?Last edited by loady; 4th Sep 2013 at 15:09.
BD Rebuilder has options to remove sections you don't want and still retain the menus and chapters while compressing to fit a 25gb disc. BD Rebuilder has no decryption capability though, so you would have to rip the movie to the hard drive first using AnyDVD HD, DVDFab or MakeMKV.
DVDFab has a free section called DVDFab HD Decrypter that will continue to function as a decryption/ripping program even after the trial for the main blu ray decryption section has ended. MakeMKV is free to use while in beta (and has been in beta for years), but you would need to rip using the Backup mode in order to get the entire blu ray to the hard drive. You will also need to get a new beta key each month or so from here: http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
AnyDVD HD is the best of the decrypters, but there is no free option after the trial.
Here is one guide for BD Rebuilder, a bit old now, but should get you started: http://club.myce.com/f32/bd-rebuilder-guide-313227/
When keeping menus and chapters, you will be making blu ray video, which will play on your blu ray player and PS3, but not on that XBox360. This is assuming you don't make backups of any blu ray with Cinavia DRM in them.Last edited by Kerry56; 4th Sep 2013 at 15:52.
Yes, of course, as Kerry56 explained. But your original post was about downloaded movies (no menus, and no longer Blu-Ray compliant).
i have one bluray player in the house and ps3 and xbox 360..is it possible to do it in such a way that it would play on all three devices ?? -
thanks Kerry..very concise !!.
Also, using said tools...could i compress to dual layer dvd and use as if it were a bluray in the bluray player and ps3 ? -
I would just toss the DVD player and get an inexpensive Blu-Ray player. I picked up a Samsung (BD-F5100 ~$70US) at BB and it's plays my HD MKVs that I've compressed down to 8GB from a BD disc with RipBot. It also plays commercial BDs, DVDs and some other formats. (Playback Formats: MPEG-2, MPEG-4, JPEG, DivX HD, AVCHD, MKV, WMV) If you were to compress a BD down to 4.37 GB and put it on a DVD blank, it would probably play that also. It will also play Netflix and Youtube and video from a USB drive. I was a bit surprised that it plays almost as much as my WDTV box.
Probably the downside is the only video output is HDMI, though the audio out can be coaxial.
I compress my DVDs to MKV with VidCoder and put about 15 - 18 on a single layer BD disc and it plays them back also.Last edited by redwudz; 4th Sep 2013 at 16:22.
Old films to high definition?
By therock003 in forum RestorationReplies: 39Last Post: 1st Jan 2015, 08:27 -
High definition DVD
By rene-rottingham in forum Newbie / General discussionsReplies: 13Last Post: 21st May 2010, 06:35 -
High definition conversion
By kypreo in forum Video ConversionReplies: 10Last Post: 21st Mar 2010, 22:15 -
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 07:57 -
By SgtPepper23 in forum AudioReplies: 1Last Post: 5th Dec 2009, 21:33
