When a show is playing in vlc how do i get the episode to appear on screen so it stays when it switches to next episode
Results 1 to 13 of 13
Can you explain in detail what you want? A show? Episode in what kind of file,dvd,stream,etc?
Try also search or ask in http://forum.videolan.org/ -
i want something like this http://www.justin.tv/lmtv_us6 i need for the episode number to be displayed when playing and for it to show when the next episode plays i've already asked on vlc forum they hardly reply to posts
the files are avi and mkv when the video starts the display shows the file name and episode but it disappears i need for it to stay i found this addon http://addons.videolan.org/content/show.php/Media+Context?content=143241 does anyone know how i can install it
I see. Download the .lua file and try put in
You must put the file in the folder:
- Windows (all users): %ProgramFiles%\VideoLAN\VLC\lua\extensions\
- Windows (current user): %APPDATA%\VLC\lua\extensions\
- Linux (all users): /usr/share/vlc/lua/extensions/
- Linux (current user): ~/.local/share/vlc/lua/extensions/
- Mac OS X (all users): /Applications/VLC.app/Contents/MacOS/share/lua/extensions/ -
I have windows 7 i went to this http://addons.videolan.org/CONTENT/content-files/143241-Media-Context.lua and clicked save as but nothing happens it says cannot be found
What says "cannot be found"?
Try right click on http://addons.videolan.org/CONTENT/content-files/143241-Media-Context.lua and choose save as or similar. -
this is what i'm seeing http://tinypic.com/r/2rng6dl/5 http://tinypic.com/r/f1wowp/5
I did that but i don't see an extensions folder http://tinypic.com/r/2uemnb9/5
does anyone know how to change the size of the title display? http://tinypic.com/r/2dlumx2/5 i went into preferences to change font size nothing happened this code was used $N$_$D$_$L
VLC Blu-ray plugin - Watch encrypted Blu-rays directly in VLC 2.0+
By Baldrick in forum Latest Video NewsReplies: 63Last Post: 23rd Feb 2014, 21:34 -
VLC:How can I add new/outer fitler or decoders to VLC?
By dayangwc in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2013, 06:33 -
Replacement for Tivo NowPlaying Widget?
By whoisquilty in forum MacReplies: 7Last Post: 22nd Oct 2012, 07:45 -
Is there a 2.0.1 version of VLC now?
By gastrof in forum Newbie / General discussionsReplies: 3Last Post: 7th May 2012, 19:10 -
VLC 0.9.2 released
By Brazil in forum Latest Video NewsReplies: 0Last Post: 15th Sep 2008, 10:25
