I have noticed that when I rip region 1 DVDs I get horizontal grey lines in some frames. This does not happen when I rip Region 2 DVDs.
I use smart ripper, DVD2AVI and TMPGEnc.
Can someone please tell me what to do to correct this?
Thanks in advance.
I take it since you ripped region 2 you know that the fps on region 1 is 29.97 and pic is 480x480 r u loading the nstc film or nstc template? what are you converting to vcd svcd the more info you give thses guy's the more help they are. Post some more info and see. I had a similar problem and i was just loading the wrong template.
i'm assuming you made your dvd-rom "region-free", otherwise, you wouldn't be able to play both region 1 and 2 dvds on your dvd-rom to unlock the files for smartripper....
what does dvd2avi's info box tell you about the source video? is it NTSC, interlaced or FILM, progressive?
Converting DVDs from Region 1 (NTSC) to Region 2 (PAL)
By Astronautilus in forum Authoring (DVD)Replies: 8Last Post: 10th Feb 2012, 04:35 -
Ripping a BD from a different REGION to the one you're in ???
By phase52001 in forum Blu-ray RippingReplies: 9Last Post: 16th Sep 2011, 17:15 -
Ripping Region 1 disc to burn Region 2/Free ?
By Alan Rouge in forum DVD RippingReplies: 7Last Post: 28th Sep 2010, 21:09 -
Questions about Ripping Foreign-Region DVDs
By animefan in forum Newbie / General discussionsReplies: 3Last Post: 9th Apr 2010, 03:39 -
new to ripping dvds
By lm932 in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2007, 08:37
