When i'm playing a series with dual audio its in japanese i selected the audio track choosing english but it doesn't stay the same when next episode plays i've tried preferences audio and entering en and english nothing happened how do i select english? so vlc can play the next episodes in english i tried english, en and eng when i click on audio tracks track 2 is for english it plays in english but when switching to the next episode it changes back to japanese
here is one of the videos i need for it to stay on english when next episodes play another video i have of a different show i have no problem with it the video is english even when next episode plays
General
Unique ID : 203438903320308461048996425089411310624 (0x990CE856E308EDB38BCF2673A885E420)
Complete name : C:\Users\Leon\Videos\Fullmetal Alchemist BrotherHood 01.mkv
Format : Matroska
Format version : Version 2
File size : 315 MiB
Duration : 24mn 27s
Overall bit rate : 1 803 Kbps
Encoded date : UTC 2012-06-19 00:41:44
Writing application : mkvmerge v5.6.0 ('Kenya Kane') built on May 27 2012 16:44:04
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Attachment : Yes / Yes / Yes / Yes
Video
Format : AVC
Format profile : High@L5.0
Format settings, CABAC : Yes
Format settings, ReFrames : 10 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 24mn 27s
Nominal bit rate : 1 500 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.068
Writing library : x264 core 104 r1683 62997d6
Encoding settings : cabac=1 / ref=10 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=10 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=1500 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=2:0.60
Default : Yes
Forced : No
Audio #1
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 24mn 27s
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : 9ms
Default : Yes
Forced : No
Audio #2
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 24mn 27s
Default : No
Forced : No
Text #1
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Title : [ASS]
Default : Yes
Forced : No
Text #2
Format : ASS
Title : [ASS] [FOR DUB]
Default : No
Forced : No
Menu #1
00:00:00.000 : en:Prologue
00:00:58.800 : en:Opening
00:02:28.857 : en:Part A
00:10:55.238 : :Part B
00:22:27.555 : en:Ending
00:23:57.353 : en:Preview
Menu #2
00:00:00.054 : en:00:00:00.054 / en:00:00:00.054 -
This video does not have a language tag to select. That's the reason why it does not work with your setting.
There is another way to keep audio track by selecting its track number of the stream. -
Load them into mkvtoolnix ... click to highlight desired default audio ... down below set option to "default track yes" and "forced track yes" ... do this for all problematic mkv's
Audio language is nice to have especially if changing format but is not required or cause such playback faults. -
thanks how do i save the files into its own folder when i select default audio tracker it adds the english file into the same folder the japanese show is in
mkv dual audio -> mp4 dual audio using AVS and FormatFactory
By begna112 in forum Video ConversionReplies: 2Last Post: 19th Nov 2012, 22:22 -
VLC not playing MKV
By stringcheesy in forum Software PlayingReplies: 1Last Post: 19th Mar 2011, 04:29 -
Dual Audio Tracks Playing After K-Lite Codec Pack
By Boris_yo in forum Video Streaming DownloadingReplies: 9Last Post: 7th Jan 2011, 07:57 -
Trouble playing mp4 in VLC, audio is there, but no video
By brdhsby5 in forum Newbie / General discussionsReplies: 6Last Post: 9th Feb 2010, 14:06 -
a few m4v files have no audio when playing in iTunes...work fine in qt/vlc
By bobogs in forum DVD RippingReplies: 0Last Post: 18th May 2009, 21:21
