some of my videos are too red, or too dark, or too blue.
I am a very occasional editor of my videos and would prefer freeware.
Results 1 to 21 of 21
If you want the most kickass, free color corrector, and your computer can handle it, and you're wiling to learn, try Blackmagic Resolve Lite.
Otherwise go with VirtualDub. -
none of the VirtualDub filters seems to apply to color - only to brightness/contrast.
smrpix: I assume you mean DaVinci Resolve. I'm looking at it but haven't yet figured out how to use it. -
You haven't looked hard enough:
http://www.infognition.com/VirtualDubFilters/color_correction.html -
Yes, Davinci Resolve (Lite) is a Blackmagic product.
It really is the most powerful free color-correction product available. It really does take some effort to learn to use it. If you're having trouble finding the filters in Virtualdub, Resolve is probably not what you want.
My answer may have been a bit of an overreaction to too many posts using using "free" and "best" in the same sentence (which mercifully, you did not do.)
Good luck. Post samples if you want specific advice. BTW, the early chapters of the Resolve manual (free download) are an excellent overview of color correction. -
I installed the needed Virtualdub filter; the preview shows that it works. But I don't know how to save it. There's nothing in that particular window, and going to "File > Save as" doesn't do it either.
I'm sorry I'm so ignorant! -
VirtualDub internal color filters: HSV Adjust, Red/Green/Blue Adjustment, Grayscale.
VirtualDub isn't great for color correction. It only works on some types of color errors.
Avisynth is fairly crappy to work with for this.
For this, Premiere is often best.
The only way to improve on Premiere is to use DaVinci.Want my help? Ask here! (not via PM!)
What about ColorMill and gradation curves, used with histogram and a pixel reader? Not as fancy or multi-windowed as Colorista or ColorFinesse in Adobe's apps, but the vDub versions are (ahem) free, definitely a cut above the built-in filters, and they can be easily chained in the filter list.
Out of curiosity, I downloaded ColorMill; I "saved" it to my Documents. It "Express Installed" but I can't find it - not even through "Search"; where is it?
If it installed correctly you'll find it listed in Video->Filters->Add, along with the other available filters, some built-in, others added in by you.
I've got ColorMill.exe, but not ColorMill.vdf.
ColorMill.exe is one of a few non-.vdf in a list of .vdf which includes a.o. rgbeq.vdf.
Anyway, I'm happy with what I now can do. -
I think you downloaded the wrong thing. The Colormill archive contains only Colormill.txt and colormill.vdf.
"rgbeq.vdf" is a different filter. You can use it in VirtualDub, but it's interface is different and it's rather more complicated to get the hang of using it. It's formal name is "RGB Equalizer" and it allows you to adjust color response at up to 17 different points. I think the gradation curve plugin would be much easier to use and is more like the curves filters in Photoshop Pro, AfterEffects, etc.
Software that adjusts color and brightness of video
By ericdunn in forum Newbie / General discussionsReplies: 5Last Post: 24th May 2010, 06:48 -
Good consumer LCD TV for VHS transfer without auto color/brightness
By OldMedia in forum RestorationReplies: 0Last Post: 1st May 2010, 01:02 -
Need Editor for Contrast, Brightness, Color Saturation
By HorseTears in forum EditingReplies: 1Last Post: 15th Dec 2009, 10:32 -
How to adjust Color/Brightness/Contrast/Etc in firewire camera?!?! PLEASE..
By vegassteven in forum Newbie / General discussionsReplies: 7Last Post: 14th Dec 2008, 06:54
