    Jul 2013
    Hello everyone
    Today i tried to shrink a large BluRay to BD25
    I have done many of these over the last few weeks with no issues at all.
    Only difference today was this BD was 55GB where as the others which worked were 40+ GB
    Anyways the problem today was it completed the work but the output was only 6.5GB (Tried it 3 times and it completed fast too)
    The disk i was trying to do was a 3D version if that is any help
    I checked all settings and nothing has changed (Output set to BD25)
    Any ideas what the problem could be
    Thanks in advance for any help
    Oct 2005
    666th portal
    Jul 2013
    Thnx for the reply.I did search the forum but never saw that post.
    Appreciate your help
  4. If you're seeing 55 GB, it's possible the problem is new protection, so first thing to do is to update your decrypter. Of course no disc is actually going to be 55 GB. AFAIK, BDRB should be able to handle the 2D portion alright regardless of whether the disc is 3D or not. I was able to do the DREDD BD and there's only one version of it. The 2D view is the left view only.
    Pull! Bang! Darn!
    Jul 2013
    Thnx fritzi93
  6. Have you tried movie-only? That should work regardless. If not, Clown_BD will extract 2D main movie from any 3D disc reliably. And I presume you're doing a 2D backup, because re-encoding a 3D disc just ain't happening (see aedipuss' link above).
    [EDIT] Oh, and welcome to the forum.
    Pull! Bang! Darn!
    Jul 2013
    Thanks for the welcome and ill try the 2D
    Thanks again
