I've been ripping American Dad DVDs to mkv with makemkv and then encoding them to h264 format in handbrake. The files are about 700mb and are encoding to about 100mb. There is very little noticeable difference in quality. I've never seen the compression be so good. Is anime somehow easier to encode or something?
That type of animation is easier to compress.
There is less motion, more repeat frames, and not very many details (compared to say, a live action movie). All these things make video easier to compress -
American Dad isn't anime:
http://en.wikipedia.org/wiki/Anime
It's a very simply drawn cartoon (or animation, if you prefer).
You have to know what to look for. While they're probably fine, as pdr mentions that kind of stuff is so simply drawn with so many repeated frames that it's easy to compress. Look for the mosquito noise. That's the little dots outside the lines. And then compare to the source. Better, perhaps, would be not to encode to a specific size, but to a specific quality. Try CRF 18 and see if the filesize is much larger....and then encoding them to h264 format in handbrake. The files are about 700mb and are encoding to about 100mb. There is very little noticeable difference in quality. -
Thank you. I'm glad somebody mentioned it. I certainly wouldn't call The Simpsons or Family Guy anime - which is the "type" of animation that American Dad is.Originally Posted by manonoDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Best settings for anime encoding?
By The Scenes in forum Newbie / General discussionsReplies: 5Last Post: 14th Dec 2011, 18:28 -
Anime encoding help
By carasy in forum Video ConversionReplies: 3Last Post: 28th Nov 2010, 18:07 -
help encoding anime w/ handbreak
By Ronin Silfar in forum DVD RippingReplies: 22Last Post: 29th Jan 2010, 21:28 -
Encoding anime
By prnoct90 in forum Video ConversionReplies: 3Last Post: 25th Nov 2009, 05:38 -
Anime Encoding From DVDs to h264.
By kwanbis in forum Newbie / General discussionsReplies: 9Last Post: 11th Mar 2009, 19:31
