I have an old PC with AMD Duron 1.20Ghz, 480MB DDR RAM, 18GB HDD Seagate 4MB cache PCChips motherboard M810DLU Windows XP Pro 32bit my burner is a Samsung SH-S182F 2MB buffer and burn a data disc of 2.61 GB using the program Imgburn at 4x burning for two hours and to extract all the contents of the disc to the PC is 8 hours
after burning the disc did a scan disk using nero DiscSpeed and no error found
is this normal? why is that? can someone explain me?
my HDD manufacturer Seagate
Hard disk name U Series X 20014
Figure 3.5 "
Capacity after formatted 20 GB
discs 1
Recording Surfaces 1
Physical Dimensions 147.0 x 101.9 x 19.99 mm
Weight 455 g
Rotational latency 5:55 ms
Rotational Speed 5400 RPM
Maximum internal transfer coefficient 445 Mbit / s
Average Seek Time 12.7 ms
interface Ultra-ATA/100
Transfer Rate Buffer to host 100 MB / s
Buffer Size 2 MB
Results 1 to 11 of 11
Are you going to check to see if your burner was stuck in PIO mode or are you going to talk about your motherboard next?
Checking DMA status: http://club.myce.com/f61/troubleshooting-enabling-checking-dma-windows-vista-xp-2000-me-9x-101616/
There are instructions in there for XP. -
Click on the link I provided in my previous post and read the step by step instructions on how to check if your optical drive is in PIO mode. The instructions for XP are in the middle of that page.
has nothing in PIO mode
Primary IDE Channel: Device 0 DMA if available, Ultra DMA Mode 5 Device 1 Auto Detect DMA if available
Secondary IDE Channel: Device 0 DMA if available, Ultra DMA Mode 2 Device 1: Automatic detection, DMA if available -
No surprise with such an old hdd bugger.
20 GB ....bah!*** Now that you have read me, do some other things. *** -
I do not think the problem is the HDD because I already used the Satools for DOS on it and no problem detected
as I said before everything is set in DMA and automatic
I realized that the buffer cache my HDD and my DVD recorder is 2MB, slow to burn and extract files on DVD may be because of that?
when recording is stopped and after a while begins to burn and break this happens repeatedly until the desired recording that takes 2 hours to extract all the contents of the disc to the PC is 8 hours
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
how to extract meta data from a DVD?
By Toastie in forum Authoring (DVD)Replies: 5Last Post: 11th Aug 2011, 00:12 -
Why I get a data disc every time when I burn BD-5 ?
By mahogany in forum Authoring (Blu-ray)Replies: 7Last Post: 6th Dec 2009, 04:10 -
DVD Data Disc
By DuBsTaR in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2009, 05:31 -
extract dvd menu text & time
By msdiane in forum Newbie / General discussionsReplies: 0Last Post: 26th Oct 2008, 12:25
