Hi! First post. A few years ago a bought a 3m mpro150 pocket projector and it was awesome--- to hook up to my computer. But that defeats the whole portability thing-- and my main reason for buying it was to be able to project videos from its 1 Gig internal memory anywhere and everywhere for instillation and art and stuff.
The file types it accepts aren't too limited but I have not been able to get the video function it to work. I've only gotten a video to play on one occurrence a long time ago. I'm trying to figure out how I'm covering my files wrong, and what do I have to set things in adobe media encoder to line up with the specs of the device.
The accepted file types are (supposedly) as follows:
File Container Video Format Audio Format
*.g3pp MPEG-4 SP, MPEG-4 ASP, H.264 AMR-NB, AMR-WB
*.g3p2 MPEG-4 SP, MPEG-4 ASP, H.264 AMR-NB, AMR-WB
*.mp4 MPEG-4 SP, MPEG-4 ASP, H.264 MP3, AMR-NB, AMR-WB, AAC
*.avi MPEG-4 SP, MPEG-4 ASP, H.264 MP3
*.mov MPEG-4 SP, MPEG-4 ASP, H.264 AMR-NB, AAC
Maximum Video Resolution: 720x480 (NTSC) / 720x576 (PAL)
Maximum Frame Rate: 30 fps
Maximum Audio Channels: Stereo
I have tried converting mp4, mov mp4, h264, mpeg2, mov h264-- I feel like I have tried every friggin combo under the sun to no avail. What am I doing wrong? Also the "mov and avi" support are BS because I've tried playing both on the device.
I use the open source program HandBrake (https://handbrake.fr/) . As long as the video codec says mpeg-4, most files will work. 720x480 for sure with either AAC or MP3 audio tested and confirmed good. Oh, I should also say the files need to be renamed ".mp4" after conversion. I have also used ".avi" files at 640 x 480 with higher bit rates. All of these files are 23 fps.
Yeah .... I decided to post since I was looking for some help with this myself after picking one up for the kids. It works as a great sleep-over movie night. If it's pitch black, the projector works great! Maybe blow the dust of eh?!
Guys I just wanted to post a thank you note.
I am in love of vintage tech and recently acquired a 3m mpro 150 projector. Instantly I was faced with the same problem.
Your post helped me successfully format the file for the projector. - Many thanks
Also hoping to keep this thread online for future users.
iGo Projector/Flip File Format
By cademichaels in forum Portable VideoReplies: 1Last Post: 12th Aug 2013, 10:30 -
Portable DVD Player vs Portable Video Player
By DJboutit in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2012, 17:28 -
How to get output file size before converting a file using ffmpeg?
By hayden in forum ProgrammingReplies: 1Last Post: 26th Feb 2012, 07:04 -
Converting a AVI file, want to add another video file
By s_joy09 in forum Authoring (DVD)Replies: 7Last Post: 7th Aug 2010, 14:40 -
Converting an MPG file to an ISO file.
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 13th Dec 2009, 21:58
