Ive been trying to create a DVD with a custom picture before the main movie using dvdflick but I dont know whats going on. Is it possible to do this using dvdflick? How can I do this? And also what is the difference between a vcd and a dvd
What is VCD - https://www.videohelp.com/vcdWhat is DVD - https://www.videohelp.com/dvd
Wikipedia also has information.
\VCD is limited to 352x240 (NTSC) or 352x288 (PAL) progressive MPEG-1 video at bit rates of 1150 Kbps or less and MPEG-1 layer II audio at 224 Kbps and 44.1 KHz and 2 channels (no 5.1 audio allowed). VCD is the first video format that fits on CD media so it's very old. The low resolution and video bit rates limit the quality quite a bit. They are still being made in parts of Asia and Eastern Europe but the format was never really introduced into places like Japan, North America and Western Europe. VCD subtitles must be hard coded into the video and as the format only supports one audio stream, manufacturers have resorted to things like "Left speaker Cantonese, right speaker Mandarin" which can be seriously annoying if your playback device or software does not allow you to play only one speaker on such VCDs.
DVD uses DVD media and has significantly higher bit rates for video and audio than VCD allows and is almost always made from MPEG-2 video, which can be progressive or interlaced. MPEG-1 video is allowed for DVD with some limitations. DVD resolutions are typically larger than VCD. DVD has selectable subtitles (can turn them on/off) and multiple audio tracks are allowed.
Inserting still pictures into a DVD movie
By efiste2 in forum Authoring (DVD)Replies: 3Last Post: 5th May 2013, 03:42 -
How to create .mk3d file with two pictures?
By webmastor0 in forum Video ConversionReplies: 4Last Post: 13th Dec 2012, 04:03 -
Create a video from several pictures
By snewt in forum ProgrammingReplies: 1Last Post: 29th May 2011, 19:45 -
How to create a DVD in Windows 7 Movie Maker
By edong in forum Authoring (DVD)Replies: 1Last Post: 17th Apr 2010, 21:32 -
taking a mpeg video to create thousands of pictures
By rcmpayne in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2008, 14:45
