I recently learned how to hardsub videos using XviD4PSP but it takes a really long time to complete the process. I managed to hardsub 2 videos and it took me the entire day.
Is there any way to make the encoding process any faster without losing the audio/video quality in the final output? Like some options I need to tweak?
Not really sure what sufficient info I should provide but here's the log (or whatever it's called) of the video that just recently got successfully hardsubbed:
PLATFORM
OS Code: Microsoft Windows NT 6.1.7601 Service Pack 1
OS Name: Windows 7 Home Basic Service Pack 1 (x32)
Framework: 2.0.50727.5472 (v4.0)
AviSynth: AviSynth 2.60, build:Mar 9 2013 [13:28:27]
CPU Info: Intel(R) Atom(TM) CPU N2800 @ 1.86GHz (~1862), 4 core(s)
RAM Total: 2036Mb
Language: ENP (1252, ".")
SystemDrive: C:
XviD4PSP
Version: 5.10.330.0
Created: 19.03.2013 07:34:12
AppPath: C:\Program Files\XviD4PSP 5
TempPath: D:\Temp
FILES
[Final8]Mirai Nikki - 02 (BD 10-bit 1280x720 x264 AAC)[2AE6C97E].mkv >
TASK
Format: MKV
Duration: 00:23:47:845 (34234)
VideoDecoder: DirectShowSource
Resolution: 1280x720
Aspect: 1.7778
VCodecPreset: x264 Q21 HQ Film
VEncodingMode: Quality
VideoCodec: h264 > x264
VideoBitrate: 2396 > Q21.0
Framerate: 23.976
SourceType: PROGRESSIVE
FieldOrder: UNKNOWN
AEncodingPreset: AAC-LC VBR 0.45
AudioCodec: AAC
AudioBitrate: 0
Samplerate: 48000
Channels: 2
Normalize: 100%
Accurate: 10%
Gain: 1.999
Delay: 9 > 9
SCRIPT
Import("C:\Program Files\XviD4PSP 5\dlls\AviSynth\functions\AudioFunctions.avs")
Import("C:\Program Files\XviD4PSP 5\dlls\AviSynth\functions\VideoFunctions.avs")
LoadPlugin("C:\Program Files\XviD4PSP 5\dlls\AviSynth\plugins\VSFilter.dll")
DirectShowSource("C:\Users\A C E R\Desktop\[Final8]Mirai Nikki - 01-26 (BD 10-bit 1280x720 x264 AAC)\[Final8]Mirai Nikki - 02 (BD 10-bit 1280x720 x264 AAC)[2AE6C97E].mkv", fps=23.976, convertfps=true)
DelayAudio(0.009)
ConvertToYV12()
###[FILTERING]###
###[FILTERING]###
TextSub("C:\Users\A C E R\Desktop\[Final8]Mirai Nikki - 01-26 (BD 10-bit 1280x720 x264 AAC)\Subtitles\[Final8]Mirai Nikki - 02 (BD 10-bit 1280x720 x264 AAC)[2AE6C97E].ass")
AmplifydB(1.999)
AUDIO ENCODING
Encoding audio to: D:\Temp\0002.m4a
AAC Q0.45 2ch 16bit 48000khz
neroAacEnc.exe: -ignorelength -q 0.45 -lc -if - -of "D:\Temp\0002.m4a"
VIDEO ENCODING
Encoding video to: D:\Temp\0002.264
x264 Q21.0 1280x720 23.976fps (34234 frames)
x264.exe: --crf 21.0 --ref 8 --deblock -1:-1 --direct auto --b-adapt 2 --trellis 2 --no-fast-pskip --psy-rd 1.0:0.1 --partitions all --me umh --rc-lookahead 50 --sar 1:1 --output "D:\Temp\0002.264" "D:\Temp\0002.avs"
avs [info]: 1280x720p 1:1 @ 2500000/104271 fps (cfr)
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64
x264 [info]: profile High, level 4.0
x264 [info]: frame I:350 Avg QP:15.99 size: 88239
x264 [info]: frame P:10345 Avg QP:19.02 size: 14096
x264 [info]: frame B:23539 Avg QP:22.98 size: 3499
x264 [info]: consecutive B-frames: 3.9% 7.7% 16.4% 72.0%
x264 [info]: mb I I16..4: 17.5% 54.2% 28.3%
x264 [info]: mb P I16..4: 2.9% 5.3% 1.4% P16..4: 43.0% 6.8% 9.5% 0.3% 0.1% skip:30.7%
x264 [info]: mb B I16..4: 0.2% 0.5% 0.1% B16..8: 29.7% 2.4% 0.6% direct: 1.2% skip:65.3% L0:44.1% L1:52.8% BI: 3.1%
x264 [info]: 8x8 transform intra:56.0% inter:64.8%
x264 [info]: direct mvs spatial:100.0% temporal:0.0%
x264 [info]: coded y,uvDC,uvAC intra: 56.7% 54.5% 26.6% inter: 6.2% 8.3% 0.8%
x264 [info]: i16 v,h,dc,p: 31% 23% 6% 40%
x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 14% 17% 27% 5% 8% 6% 9% 6% 7%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 24% 18% 18% 6% 8% 7% 7% 6% 5%
x264 [info]: i8c dc,h,v,p: 58% 19% 17% 6%
x264 [info]: Weighted P-Frames: Y:2.3% UV:1.2%
x264 [info]: ref P L0: 56.6% 7.4% 17.2% 6.0% 4.3% 3.6% 2.8% 1.8% 0.4% 0.0%
x264 [info]: ref B L0: 79.0% 9.3% 5.7% 2.3% 1.9% 1.3% 0.6%
x264 [info]: ref B L1: 93.7% 6.3%
x264 [info]: kb/s:1451.50
x264 [total]: encoded 34234 frames, 1.59 fps, 1451.50 kb/s
MUXING
Video file: D:\Temp\0002.264
Audio file: D:\Temp\0002.m4a
Muxing to: C:\Users\A C E R\Desktop\Mirai Nikki Output\[Final8]Mirai Nikki - 02 (BD 10-bit 1280x720 x264 AAC)[2AE6C97E].mkv
mkvmerge.exe: -o "C:\Users\A C E R\Desktop\Mirai Nikki Output\[Final8]Mirai Nikki - 02 (BD 10-bit 1280x720 x264 AAC)[2AE6C97E].mkv" --engage no_cue_duration --engage no_cue_relative_position --default-duration 0:23.976fps -d 0 -A -S "D:\Temp\0002.264" -a 0 -D -S --no-chapters "D:\Temp\0002.m4a" --output-charset UTF-8
TIME
Total encoding time: 6 hour 3 min 59 sec
Out file size is: 271.67 mb
P.S. I have little to no technical knowledge when it comes to these things so please make your answers as easy-to-understand as you can.
Results 1 to 9 of 9
The main problem is your CPU. An intel atom n2800 isn't really enough for hd h264 encoding.
You could try make a xvid avi and see if it's any faster. -
No, change to avi hardware. And it should use the xvid codec and mp3.
Or do you must use x264/h264? -
When I switched the format to AVI Hardware, video encoding was set to MPEG4 1P 1500k Turbo and the audio encoding was set to MP3 CBR 128k. Should I change those to another ones or...? (If so, what specific options should I choose?)
Not necessarily. Anything will do so long as the audio/video quality isn't lost + encoding will be faster (faster than the previous ones I did at least). -
You need to manually set the resolution. You very badly need to search for a guide and look at it to answer your questions on this rather than expecting us to do all the work for you. I'm not trying to insult you, but you could really help yourself by finding a guide first and then asking questions afterward.
Xvid4PSP Encoding Modes
By leghorn in forum Video ConversionReplies: 2Last Post: 4th Dec 2012, 04:14 -
Is there a way on how to shutdown xvid4psp after encoding?
By mark63534 in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2011, 23:05 -
XviD4PSP Re-Encoding Error?
By Kid Boruto in forum Video ConversionReplies: 1Last Post: 26th Apr 2011, 03:07 -
Xvid4PSP not encoding
By dontpwnmebro in forum Video ConversionReplies: 1Last Post: 21st Mar 2010, 02:57 -
About x264 encoding in xvid4psp
By tofuguy in forum Video ConversionReplies: 2Last Post: 26th Oct 2008, 01:51
