Download from http://www.elycs.com/Elycs is a media tool, you can use it to backup you bluray disc, with it, you can:
- lossless output m2ts file
- lossless output mp4 file(video stream lossless output, audio stream is converted into aac/ac3)
- lossless output mkv file
- decrypt the whole bluray disc
- serve as a http media center
- play bluray disc m2ts file
But be careful https://www.virustotal.com/en/file/4591937ca2edd4c25c9804dec665fe7f44f5db5eac4084d01da...is/1377937845/
I guess it's false positives but 8 of 46 is too many to test it on my working station.
oh, I download this program from CNET, tried Mr pepper, work(played and rip to m2ts) well, as it is free, I think it is good
http://youtu.be/wgB25WBeBxA
"I'm not gonna try it - Let's get Mikey"
Hmmm, the application folder itself contains only four files, one JPG, ffplay.exe, ffmpeg.exe, and the TODO-beta.exe
The malware alert might apply only to the installer, BUT the report below suggests otherwise,
https://www.virustotal.com/en/file/4d9b92bc90ce6a3d044f004320ad6fe980825aa591830d8f85b...is/1377953871/
therefore, ...
no, thanks. -
Now it's just 1 of 44. How is the application exe file?
https://www.virustotal.com/en/file/6dce0e85d83f0274690c8422616a167fc3c3b7d27df37391421...is/1378540541/
Best Blu-Ray Ripper?
By Ar-Pharazon in forum Blu-ray RippingReplies: 82Last Post: 15th Feb 2015, 04:27 -
Need help using Xilisoft Blu-Ray ripper
By billw6560 in forum Blu-ray RippingReplies: 10Last Post: 11th Sep 2013, 00:46 -
What is the best blu-ray and dvd ripper software?
By R.STEED in forum Newbie / General discussionsReplies: 31Last Post: 27th Dec 2012, 10:51 -
A good Blu Ray Ripper
By pepegot1 in forum Blu-ray RippingReplies: 6Last Post: 28th Apr 2011, 22:19 -
Blu-ray Ripper settings
By Giampo2010 in forum Blu-ray RippingReplies: 6Last Post: 11th Oct 2010, 10:20
