  1. I have been looking for cheap ways to record games and things like that and I would bet that some people have read this far and seen the title and were able to put two and two together and see that I want to know if it's possible to record with a WinTV HRV 950Q. I know that connecting this to a console directly isn't going to work as no modern consoles have Coax Outputs but some modern TVs do! Which is why I was wondering if this device would allow you to send the video to your TV and then have a Coax Cable running from the TVs output into the WinTV HRV 950Q. Also if this is possible what would be the max resolution a Coax Cable can run? I've heard only 480p to 1080i I just want to be sure. But if the Coax cable can't carry the 1080i that the Card can support then is there a way to still get the full 1080i out of it? I mean why sell a card with a Coax input that only supports 480 while the card can actually support 1080i right?
  2. Just get an RF modulator. For example:
    http://www.amazon.com/Philips-SWS2103W-17-Moduator-Converter/dp/B001UYUNSE/
    Composite video from console to modulator, RG cable from modulator to HVR 950Q. Only standard definition supported by analog TV RF.
    HD to ATSC/QAM would require a very expensive commercial encoder/modulator:
    http://www.amazon.com/Channel-Thor-Broadcast-Digital-Modulator/dp/B00A2BZGCY/
    You'd be much better off getting an HDMI stripper and an HDMI recording device like the Hauppauge HD PVR 2.
    Aug 2006
    Forget it. Almost no modern N. American TVs have any outgoing video connections, particularly coax. If a TV does have an outgoing video connection it will be composite video, and will be labeled "monitor out" and the TV will most likely be an older one.
    To record game video with the WinTV HRV 950Q you should use the accessory cable pictured here to connect with the composite video out or S-video out from a console. The cable is supposed to be included with the WinTV HRV 950Q if you buy the complete product. If you must use coax to connect the WinTV HRV 950Q because the accessory cable is MIA, then you will need either an RF modulator or VCR to connect between the console and the WinTV HRV 950Q, and you will record from either analog channel 3 or analog channel 4. The VCR is the preferred option because it can act as a splitter. Maximum resolution will be 720x480 (interlaced) using any analog connection the WinTV HRV 950Q provides. Higher resolutions are only available via the ATSC/QAM digital tuner, but it isn't terribly feasible to use the digital tuner for video game capture.
  4. Originally Posted by usually_quiet View Post
    Most of the flat screens in my house have a coax output, they seem extreemly common to me. Also how would I be able to use the digital feature to record my game play? Seeing as it supports up to 1080i there has to be someway to get 1080i to it right?
    Aug 2006
    The only kind of outgoing coax connection that is common on TVs is for digital audio output to a receiver or a home theater system. They are RCA connections (often orange or black in color) rather than an F-type coax connection like those used for connecting an antenna or cable TV service to a TV. A digital audio connection won't work for recording video from a console game.
    Also, even if you had an outgoing F-type coax connection on your TV, console game video input to a TV isn't a modulated ATSC or QAM signal and your TV does not include the equivalent of a $4700 encoder/modulator to convert HDMI or component video input into an ATSC or QAM signal.
  6. Originally Posted by Upstagebuffalo View Post
    They probably function only as a pass through. Ie, what comes in on the coax input goes out on the coax output. Other inputs are likely not output to the coax. You might as well try it and see but don't get your hopes high. And even if it does work, it will be SD only.
    When your capture devices captures ATSC or QAM video it is simply "downloading" the already compressed digital stream. It is not capturing HD analog video and compressing it. It doesn't have that ability. So the only way to to capture HD output from a game console with your 950Q would be to use a device that captures and compresses HD video then modulates it onto an ATSC/QAM channel. Only broadcasters need that type of compressor/modulator so there are no consumer priced devices that do it.
