Hi iam using DVD IT PE 2.5
The mpeg file is 2,113,205,991 bytes but how comes when i put it on dvd it the file becomes 2.64gig. Why does the file increase and how can i stop that does any one have a bitrate callautor as the vcd bitrate does not give good results as a two hours of dvd should a video bitrate of 4.5 mb and usdio of 128. the file size is lower than 4.3gb, but is there a dvd software that does not take as much file size.
There could be a couple of explanations for this.
Your PC and your DVD software view file sizes in different ways. In PC terms 1Mb = 1024Kb but in DVD terms 1Mb=1000Kb. If you do nothing to the file other than load it into DVDit and DVDit reports the increased file size then that's the probably cause.
If however, DVDit reports the correct file size but the filesize increases when you burn it may be because your original file was variable bitrate but DVDit re-encodes to constant bitrate which will up the file size a bit.
Worth a try.
Fans are crazy!!
By alintatoc in forum ComputerReplies: 19Last Post: 4th Jul 2009, 05:13 -
Something for the hd dvd fans
By cracula in forum Latest Video NewsReplies: 4Last Post: 21st Mar 2008, 00:33 -
Any Simpsons fans here?...or anyone from China?
By lordhutt in forum Off topicReplies: 6Last Post: 13th Mar 2008, 21:07 -
Stargate fans here?
By mjvgiese in forum Off topicReplies: 7Last Post: 31st Oct 2007, 15:22 -
Do my fans indicate... stress??
By makntraks in forum ComputerReplies: 7Last Post: 14th Oct 2007, 19:14
