Hello
I need convert one movie and i want to increase the resolution.
For example, if i have a movie with a resolution 1280x544 i want to put 1280x720.
I want a program to do a good conversion in short time (+/-1h)
Thanks in advance.
By adding black bars above and below, right? And not by stretching it so people look too tall and thin?
Anyway, in what format is this movie? If you don't know, please post the text information from MediaInfo. And why do you want to do this?
Maybe uncropMKV is what you want. And maybe not:
https://www.videohelp.com/tools/uncropMKV -
I do this sort of thing when converting MKVs for DVD by using AviSynth scripts to add the black bars and resize, before reencoding. If there are other all-in-one programs that will do this for you, then someone else will have to help because I don't use them.
Maybe your problem is variable frame rate, not sure, but the audio isn't supposed to get unsynchronized during conversion. Mine never have. Sorry, not much help.
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
Video8 Conversion: Best trade-off for digital conversion ?
By ghl1 in forum Video ConversionReplies: 12Last Post: 6th Mar 2010, 18:36 -
Help with movies on cd's
By deb4tlj in forum Newbie / General discussionsReplies: 10Last Post: 13th Aug 2009, 13:02 -
Movies
By neha28 in forum Video Streaming DownloadingReplies: 2Last Post: 4th Feb 2009, 02:11 -
Best xvid parameters for DV movies conversion
By Boro72 in forum Video ConversionReplies: 1Last Post: 18th Jan 2009, 08:47
