Results 1 to 9 of 9
  1. Hello first time poster so I hope I dont sound foolish. I am converting a large number of personal dvd's to MP4 and store on an external drive. Which I can plug into a small box plugged into a hdmi cord to my tv which allows me to play them without the hunderedes of disks to go through. My issue is that on the TV the MP4 is square and my flat screen is not. Is there a way to rip the dvd to an aspect ratio or something that will be able to fit my tv full screen? I have tried winxdvd ripper and dvdfab both free versions. I am willing to pay if the software will do what I need. any help would be great. Thanks
    Thank you
    Are your dvds 4:3? And your tv 16:9? So you get black border at left and right. You must then crop it to 16:9.
    Or are you getting black borders at top and bottom?
    Can't you use any zoom setting on your tv?
  3. Yes its a left and right black sides issue sorry for leaving that out. If I go into the tv settings and set to stretch it will fill the screen . I was hoping that maybe there was a way to not have to do that step.
    I still need to know what the dvd source aspect ratio is? Are those in 16:9 widescreen?
    Then open a mp4 with mediainfo, view->text and post the details here.
    I guess your mp4 player might be ignoring the 16:9 aspect ratio in the mp4.
  5. I dont know how to get the info on the DVD? but here is the info of the latest attempt I made.
    This is the player I am plugging the external drive into http://www.ebay.com/itm/231005756272?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
    General
    Complete name : I:\MP4\Hayes\Apple\JAN04DISC\JAN04DISC.Title1.m4v
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 1.50 GiB
    Duration : 1h 6mn
    Overall bit rate : 3 227 Kbps
    Movie name : JAN04DISC.Title1.DVDRip
    Album : JAN04DISC
    Encoded date : UTC 2013-08-28 03:12:42
    Tagged date : UTC 2013-08-28 04:10:35
    Writing application : DVDFab
    covr : Unknown kind of value!
    Video
    Format : AVC
    Format profile : Main@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Format settings, GOP : M=1, N=15
    Codec ID : avc1
    Duration : 1h 6mn
    Bit rate mode : Variable
    Bit rate : 3 104 Kbps
    Maximum bit rate : 4 650 Kbps
    Width : 1 024 pixels
    Height : 768 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Variable
    Frame rate : 29.970 fps
    Minimum frame rate : 14.985 fps
    Maximum frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.132
    Stream size : 1.45 GiB (96%)
    Tagged date : UTC 2013-08-28 04:10:32
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 1h 6mn
    Bit rate : 117 Kbps
    Maximum bit rate : 227 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 55.9 MiB (4%)
    Tagged date : UTC 2013-08-28 04:09:21
    Menu
    Codec ID : text
    Duration : 1h 6mn
    Bit rate mode : CBR
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    That's one crappy converter. 1024x768 and 4:3!?!?!!?! (If your dvds are 16:9 then...)
    And your player seems to support vob/mpg. Then try instead use vob2mpg on the dvd. You must rip it first(with dvdfab or anydvd). Then can you just play the mpgs on your player. But you need more space then, 4-8gb/dvd as this doesn't shrink your dvds.
    If you want to shrink the video then try a better converter like vidcoder or handbrake. Just load the dvd video_ts folders and use a preset.
  7. 4:3 material isn't supposed to fill a 16:9 screen.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    But we don't know the dvd source aspect ratio yet....
    I guess you can select the dvd video_ts folder with mediainfo and it will scan the dvds properties.
    If they are in 4:3 then just zoom on your tv...
  9. Originally Posted by Mewhing View Post
    Look at the DVD case. There's usually something about the aspect ratio. When you see the 4:3 pillarboxed image on the screen does everybody look too tall and skinny? Or do they look normal?
