I'm making Blurays (not AVCHD discs) and I was wondering what Bluray players are incompatible with discs authored with MultiAVCHD as I heard MultiAVCHD doesn't author 100% compliant Bluray discs?
Do you really expect an authorative answer to this ?
If your 'Blu-ray' disk does not play in ALL Blu-Ray players then it is not a Blu-Ray disk. Right ?
If you send out disks then you owe it to the people who recieve them to ensure that they play and not to blame the peoples' players.
And you do that by using fully compliant software and not something that clearly states 'should play' -
IIRC, some Panasonic players are supposedly iffy with multiAVCHD authored discs. Other than that, I dunno. Mind you, some early BD standalones were reportedly very picky about what they'd play on a burned BDR, whether authored with multiAVCHD or tsMuxer, or just burned discs in general. Doom9 had a thread on it with a list, but I've deleted the bookmark.
Found it, but I don't suppose it'll be much help. I don't know of any current, up-to-date list:
http://forum.doom9.org/showthread.php?t=146339&highlight=standalone+results
[EDIT] Sorry, you did say Blu-Ray and not AVCHDs. Still, you can't be completely certain a given player will even play burned BDRs, especially older standalones. And I don't know of any list for standalones and burned BDRs, whatever the authoring program used. Another variable is media used, but I presume you know that.Last edited by fritzi93; 29th Aug 2013 at 15:40.
Pull! Bang! Darn! -
There were some older players like Momitsu that could not play anything that multiAVCHD made, but such players were rare. A few major manufacturer players needed some settings tweaked in multiAVCHD and then everything was OK. The vast majority of players as far as I can tell work fine with multiAVCHD and you are worrying about a "the possibility of this happening is quite low but it's not zero" event as if it was a "the odds of this happening are greater than 50%" event.
Can Bluray players play TS h264 (ac3) Data Discs?
By VideoFanatic in forum Authoring (Blu-ray)Replies: 16Last Post: 25th Dec 2012, 12:49 -
Compatible BluRay Player
By movieguru in forum DVD & Blu-ray PlayersReplies: 13Last Post: 4th Oct 2012, 14:18 -
How to shrink a 50GB-BLURAY-movie to fit on a 25GB-BLURAY disc ?
By kulmagen in forum DVD RippingReplies: 31Last Post: 1st Feb 2012, 14:39 -
True PAL 1080i 25fps Bluray -> native 1080p 24fps Bluray?
By BilboFett in forum Blu-ray RippingReplies: 1Last Post: 27th Feb 2011, 12:29 -
Need Guide for Bluray Disc Ripping and to Make AVI (Xvid) from Bluray After
By dabas in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2010, 15:05
