  1. Member LeoKac's Avatar
    May 2012
    Tbilisi
    Hello, I know there is no best video codec or format. Because, each codec is designed for its corresponding job and situation.
    Well, here is my situation:
    I have an Android Tablet, that can play any video with any codec or format, but if the video is high quality, the playback slows down because it has slow CPU and GPU.
    Here is the system info of my device:
    Android version: 4.1.2 Jelly Bean
    Display: 1280x720
    Chipset: Nvidia Tegra 2 T20
    CPU: ARMv7 Processor Dual-core 900 MHz Cortex-A9
    GPU: ULP GeForce
    RAM: 700 MB
    Internal Storage: 20 GB
    SD card: no
    So, this is not very slow tablet but not fast enough for smooth h.264/x264 video playback.
    I know h.264 and x264 reaquire fast CPU to play video.
    So, please tell me which video format and codec is best for my situation to play 720p and HQ video smoothly on my device and not take so much memory.
    Well, I want to watch 720p and HQ movies on my slow device, and I am looking for best codec to convert a movie and not to take more than 10 GB memory. and of course the video playback must be smooth.
    Thanks you so so much.....
    Have you tried any 720p h264 in a mp4?
    If not then make a sample with vidcoder. Use the android tablet preset and make a mp4.
    You can also try different players on the android tablet like vlc, bsplayer, etc.
  3. Member LeoKac's Avatar
    May 2012
    Tbilisi
    I have tried many MP4 720p h.264 or x264 movies to play with many Android video players, but each player just slow down the playback in both mode:
    Hardware encoding
    Software encoding
    Downloaded files or have you tried convert with a android tablet preset?
  5. Member LeoKac's Avatar
    May 2012
    Tbilisi
    Well, now I converted with Android tablet preset settings with Handbrake and it works just fine.
    It plays the video just normaly.
    Thank you guys...
