hi everyone,
can somebody please help me?
how to properly calculate video data bytes and how to convert videos when converting a video from blu-ray (mpegts)?
i have old 4:3 dvd (respect ratio) = transformers generation one and blu-ray in which was ripped to mpegts.
1. can somebody please help me to get the best video quality without having the size being so big? do i use free software like handbrake or paid software like aimersoft or imtoo?
2. how do i convert my old transfer (dvd) to mkv or mp4 but with good quality and make the video have the pixels to fit the entire screen.
Not enough info about your dvd's. Your post is confusing. Are you converting DVD (MPEG) to BluRay? There's a myth that DVD is "bad". BluRay is just another version of MPEG. Re-encoding doesn't automatically make DVD "better". In fact re-encoding loses quality if not done correctly and carefully.
You can stretch your 4:3 DVD's to 16:9 if you want. We don't recommend it, and few users here will listen to complaints about stretcherd videos looking blurred or distorted. If you mean that you have 16:9 letterboxed images on your source discs, that's another story. To re-process them into full-screen 16x9 videos, be prepared for lots of work.Last edited by sanlyn; 25th Mar 2014 at 06:40.
i have old (1980s) dvd that have 4:3 aspect ratio and i want to convert each episodes to mkv or mp4 and i want the converter video file to be able to play in full screen.
tools i have are handbrake, imtoo, aimisoft
question: what do i have to do to make that happen? do i crop the video from the start of converting?
my 2nd question about blu-ray is when converting a file to mkv, how to calculate the video and audio data bite rate?
example: a single blu-ray mpegts file is 35gb, if i use imtoo converter and put the settings on high quality, the output size is still around 20gb, but i have seen some videos on the internet having the same video around 14gb but better quality.
i don't mind taking the long road, but how do i convert my files so the video quality is very high, but at the same stay around a reasonable size 12-15gb?
thanks everyone
also one more question; how do i merge 1080p m4v files together and how to merge different resolutions m4v files together? -
Handbrake
has a target size, u can type 12000-15000 in the box to get your vid size.
And u can merge vids together with MKVtoolnix.
I hope this helps...
How can I get this WMV video to convert properly?
By KushSmoka420 in forum Video ConversionReplies: 12Last Post: 9th Aug 2013, 17:07 -
Can't Render Videos Properly After Reformat
By abdullahisme in forum EditingReplies: 7Last Post: 12th Apr 2011, 08:50 -
certain videos do not play properly
By julvar in forum Newbie / General discussionsReplies: 5Last Post: 2nd Apr 2011, 14:55 -
[FFMPEG] How to properly encode compatible videos for PSP
By squadjot in forum Video ConversionReplies: 1Last Post: 22nd Dec 2009, 21:37 -
convert mov to flv zero bites
By drica in forum ffmpegX general discussionReplies: 46Last Post: 30th Aug 2009, 13:42
