I keep recording videos in the 480 x 480 resolution. However, when I go to merge them in my program and after merging I must export them... It exports the videos to a different resolution.
Pretty much; how can I edit my 480 x 480 videos and make sure they stay at the same resolution. OR be able to switch it back to 480 x 480 . thanks.
Results 1 to 10 of 10
You might have mentioned you were on a Mac. The obvious answer, if it doesn't give you the choice you want, is to use something else, anything else. Most of us here are more used to PCs where there are many choices.
480x480 is very unusual. They don't play back at that resolution, do they? Are they like NTSC SVCDs that are 4:3 and play back at 640x480? The reason I ask is that I suspect that the aspect ratio is very off at 480x480 and it's meant to be resized during playback. -
640 x 480 to DVD
By santiam in forum Video ConversionReplies: 18Last Post: 7th Jun 2013, 12:11 -
DVD resolution is 720 x 480 ??
By siratfus in forum Video ConversionReplies: 6Last Post: 3rd Mar 2013, 10:47 -
How do i make bleach 480 to mini mkv?
By brotherhood1997 in forum Newbie / General discussionsReplies: 2Last Post: 7th Dec 2011, 14:43 -
Dazzle 720x 480 Frame Drop
By genericman in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Mar 2011, 11:37 -
DVP 5990 and 852 x 480 Resolution
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 6Last Post: 4th Nov 2009, 13:29
