Results 1 to 17 of 17
  1. Member vhelp's Avatar
    Mar 2001
    New York
    test..something is screwing with the forum board.<br>
    Where?
    I'm trying to fix image uploading.
  3. Member vhelp's Avatar
    Mar 2001
    New York
    i have mixed success in latest x265 ea85b67 build.<br><br>
    <br>computer #1, desktop pc, amd dual core x2 3600+, 2g ram winxp home sp2<br><br>results: random crashes, does not completes the encode<br><br>// ------------------------------------------------------- //<br><br>computer #2, netbook, atom processor, 500mb ram, win xp home sp3<br><br>results: success, 122 frames, 720x480 24fps<br><br>y4m  [info]: 720x480 24Hz, frames 0 - 121 of 122<br>x265 [info]: detected SIMD architectures SSE2 SSE3 SSSE3 <br>x265 [info]: performance primitives: intrinsic assembly<br>x265 [info]: Main profile, Level-3 (Main tier)<br>x265 [info]: thread pool with 2 threads, WPP enabled (8 streams)<br>x265 [info]: CU size                      : 64<br>x265 [info]: Max RQT depth inter / intra  : 1 / 1<br>x265 [info]: ME method / range / maxmerge : star / 64 / 1<br>x265 [info]: Keyframe min / max           : 24 / 24<br>x265 [info]: Rate Control                 : CQP-20<br>x265 [info]: Lookahead len / -b / bAdapt  : 10 / 0 / 1<br>x265 [info]: tools: rect amp no-rdo lft sao sao-lcu sign-hide <br><br>// ------------------------------------------------------- //<br><br>computer #3, dell cpu I3 4g ram windows xp pro sp3<br><br>results: success, 122 frames, 720x480 24fps <br><br>y4m  [info]: 720x480 24Hz, frames 0 - 121 of 122<br>x265 [info]: detected SIMD architectures SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 <br>x265 [info]: performance primitives: intrinsic assembly<br>x265 [info]: Main profile, Level-3 (Main tier)<br>x265 [info]: thread pool with 4 threads, WPP enabled (8 streams)<br>x265 [info]: CU size                      : 64<br>x265 [info]: Max RQT depth inter / intra  : 1 / 1<br>x265 [info]: ME method / range / maxmerge : star / 64 / 1<br>x265 [info]: Keyframe min / max           : 24 / 24<br>x265 [info]: Rate Control                 : CQP-20<br>x265 [info]: Lookahead len / -b / bAdapt  : 10 / 0 / 1<br>x265 [info]: tools: rect amp no-rdo lft sao sao-lcu sign-hide <br>
    <br><br>@ all<br><br>i would like to make the suggestion that we on multiple cpu's. because so far, i am getting success and failure on two. <br>
  4. Member vhelp's Avatar
    Mar 2001
    New York
    <p>the "code" aren't working. and keeps inserting &lt;br&gt; and such. &nbsp;the above post should not look that way.</p><p><br></p><p>oh, thanks to quickly looking at this. i was just testing, didn't expect you to jump in...thanks again.</p>
  5. Member vhelp's Avatar
    Mar 2001
    New York
    ok, everything seems to be screwing &nbsp;
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    oops
  7. Member vhelp's Avatar
    Mar 2001
    New York
    i will come back later, i'm work work and everyone is jumping on me..
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    dfslkgjdflkgj fg
    dfg
    dfdfgdf
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    testsd
    dsfsd
    fs
    df
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    What is your browser?
    alsdkfjsdlkfjsdlkdsfj
    s
    dfsdf
  11. DECEASED
    Jun 2009
    Heaven
    Trying to answer...
  12. I'm a MEGA Super Moderator Baldrick's Avatar
    testing withoiu javascript
  13. I'm a MEGA Super Moderator Baldrick's Avatar
    Try refresh the page a few times to update all javascripts.
  14. Member vhelp's Avatar
    Mar 2001
    New York
    i'm using opera v12.16
  15. Member vhelp's Avatar
    Mar 2001
    New York
    ok, its working.. thanks for quicky fixing it.
  16. I'm a MEGA Super Moderator Baldrick's Avatar
    Does it works with ie10?
  17. I'm a MEGA Super Moderator Baldrick's Avatar
    Yes!
