Results 1 to 13 of 13
  1. Hello everyone!
    As I did not find any appropriate section for video troubleshooting, i am writing here.
    Anyways, so i took a video when i went on vacation, i turned the recoring on, then i let it record for like 5 mins but i didnt pay attention to it. Maybe something got pressed, i dont know, but later on, the video wasnt showing up on the sd card when using the camera. I pluged the SD card in my pc n the video is there. It doesnt play at all though. I tried converting it with pazera free mov to avi converter i believe but it says moov atom is missing. When i play it with gom player it says my system lacks the codec. Here is a log from Gom player if that helps:
    Stream 0
    MEDIA TYPE 0:
    [AM_MEDIA_TYPE]
    majortype: MEDIATYPE_Stream {E436EB83-524F-11CE-9F53-0020AF0BA770}
    subtype: Unknown GUID Name {08E22ADA-B715-45ED-9D20-7B87750301D4}
    formattype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000}
    bFixedSizeSamples: 1
    bTemporalCompression: 0
    lSampleSize: 1
    cbFormat: 0
    MEDIA TYPE 1:
    [AM_MEDIA_TYPE]
    subtype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000}
    lSampleSize: 1
    cbFormat: 0
    And here a MediaInfo log from another video taken with my camera using the same parameters as reference.
    Complete name                    : I:\DSCN0653.MOV
    Format                           : MPEG-4
    Format profile                   : QuickTime
    Codec ID                         : qt
    File size                        : 257 MiB
    Duration                         : 1mn 53s
    Overall bit rate                 : 18.9 Mbps
    Encoded date                     : UTC 2013-06-07 17:29:20
    Tagged date                      : UTC 2013-06-07 17:29:20
    NCDT                             : NCTG
    Video
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format profile                   : Main@L4.0
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 1 frame
    Codec ID                         : avc1
    Codec ID/Info                    : Advanced Video Coding
    Duration                         : 1mn 53s
    Bit rate mode                    : Variable
    Bit rate                         : 18.8 Mbps
    Width                            : 1 920 pixels
    Height                           : 1 080 pixels
    Display aspect ratio             : 16:9
    Frame rate mode                  : Constant
    Frame rate                       : 29.970 fps
    Color space                      : YUV
    Chroma subsampling               : 4:2:0
    Bit depth                        : 8 bits
    Scan type                        : Progressive
    Bits/(Pixel*Frame)               : 0.302
    Stream size                      : 254 MiB (99%)
    Language                         : English
    Color primaries                  : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Transfer characteristics         : BT.709-5, BT.1361
    Matrix coefficients              : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Audio
    Format                           : AAC
    Format/Info                      : Advanced Audio Codec
    Format version                   : Version 4
    Format profile                   : LC
    Format settings, SBR             : No
    Codec ID                         : 40
    Duration                         : 1mn 53s
    Bit rate mode                    : Constant
    Bit rate                         : 128 Kbps
    Channel(s)                       : 2 channels
    Channel positions                : Front: L R
    Sampling rate                    : 48.0 KHz
    Stream size                      : 1.73 MiB (1%)
    Language                         : English
    Thanks in advance, this video means the world to me.
    Try first play with vlc media player. Then mpeg streamclip.
    If they fail try video repair tool. Try the free trial and see if it can repair anything.
  3. I tried it, it didn't really help, here is the report.
    Edit: VLC n mpeg streamclip dont work.
    It doesn't look good...
  5. indeed, any suggestions? but at least it recognizes the frame size.
    Oct 2005
    666th portal
    upload it to a filesharing site and post a link if you'd like people here to take a shot at it.
  7. Kk but it is quite big so it might take me some time to upload since my internet connection isn't too fast. I'm sorry for the inconvenience.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    You could upload a few MB from it. Try use makesample and upload 10-50MB.
  9. But if its damaged, will it work if i make a sample?
    Edit: Here is the file:
    https://docs.google.com/file/d/0B_ebjDbkdUL6Wl9rUXNqWnExTlk/edit?usp=sharing
  10. Just on a lark, because I know it has a good demuxer, I tried using MMG to remux the video to an MKV file. It worked! I got a ~4 minute MKV video. The last third or so has a black picture (audio continues) but I think that's because the camera was put in the back of a car with no view. So download MkvToolnix, install it, then run MMG.EXE. Open the MOV file then press Start Muxing. Once you have the MKV file you can remux back to MOV with some MOV muxing tool, if necessary.
    I extracted the elementary audio and video streams from the MKV with MkvExtractGUI. Then used Mp4Muxer to mux those into an MP4 file. Be sure to set the frame rate to 29.97 as Mp4Muxer will default to 25 fps.
  11. OH my gosh, YOOOOOOOPIEEEE! This is for u Mr. jagabo:
    I have no idea how to thank u, thank u so so so so damn much.
  12. Glad to help out. Just dumb luck really.
