hi, how i can delet a special scene from MKV video files without Re-Encoding ?
I tested MKvmerge (Spiliting with timecodes and then appending odd parts) but it did not delet extaclty i want. i need accuracy less than 1 second.
(sorry for my EN)
You can only cut at keyframes without reencodig. They might be several seconds apart.
Some software can just reconvert around the cut but I don't know anything for mkv. Maybe solveigmm video splitter.
But you can first try the free https://www.videohelp.com/tools/SolveigMM-AVI-Trimmer and see how it works. -
If you reconvert you can cut exact. Easy with freemake video converter, use the scissor to cut.
It might work with avidemux and video to video converter also. -
Try using TMPGEnc MPEG Smart Renderer 4. This program is probably the best program that I have come across to edit video files in the MKV or MP4 format without re-encoding the whole video. It just re-encodes a small area around the cut and is frame accurate. This program however is not free and costs $69.95 US retail, but if you have purchased other TMPGEnc software you can get a user discount and purchase a license for $58.95 US. You can download a free 14 day trial before you purchase. I believe that the trial version adds a watermark, but I don't remember if there are other limitations.
VideoReDo TVSuite H.264 will work in frame cut mode. Supports AAC and AC-3 audio, but not DTS. I bought it several years ago and have been totally pleased with it and found it to be a solid investment. There is a free trial and I'm pretty sure the trial will work without putting in a watermark.
Encoding 8bit to 10bit MKV and then back to 8bit MKV
By enim in forum Video ConversionReplies: 2Last Post: 18th Aug 2013, 10:23 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29 -
Editing MKV ?
By txl in forum EditingReplies: 5Last Post: 30th Jul 2009, 10:49 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11
