i have a kiiro838d dvd player 2 weeks old that payed any dvd as soon as i put it into the player now it only plays porn dvds straight away, to play other dvds like blow and braveart i have to change the track button to select wich audio i want to play and then they work . but trying this on other dvds like 6th day it wont work at all (it comes up with language unknown ). the dvd player played all dvds without without having to make any alterations but now i have to change the audio track everytime. is this a fault on the dvd player or some way i can fix this as nothing is mentioned about this in the manual
cheers
the fact that it plays pron DVDs without problems is most likely becuase it has only one sound track.
I-ve got that machine too and have no problems. Try the Kiiro helpdesk, they normally reply on the same day.
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 01:00 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 12:55 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 18:06 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 09:15 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 06:05
