Hi,
I am seeing incorrect frame-rate for number of videos in FFMpeg 1.2 & 2.0 ...
E.g. for below video (http://files.videohelp.com/u/211860/Video_LXF.lxf) it used to be 29.97 fps earlier in old version, it is showing 14.99 now. I have verified in other tools like MediaInfo that the correct frame-rate is 29.97 only.
(Output)
(0.6.1)
C:\Users\Administrator\Desktop\FFMpeg>0.6.1\ffprob e.exe "Y:\Video_LXF.lxf"
ffprobe version N-35462-g61b1d85, Copyright (c) 2007-2011 the FFmpeg developers
built on Dec 5 2011 14:22:27 with gcc 4.6.2
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libope
ncore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en
able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger -
-enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben
c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-
libxvid --enable-zlib
libavutil 51. 30. 0 / 51. 30. 0
libavcodec 53. 40. 0 / 53. 40. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 51. 0 / 2. 51. 0
libswscale 2. 1. 0 / 2. 1. 0
libpostproc 51. 2. 0 / 51. 2. 0
Input #0, lxf, from 'Y:\Rajiv\CTS-2219 (Frame Rate generated by CTSD7.1 for LXF
formats is wrong)\Video_LXF.lxf':
Duration: 00:00:16.88, start: 0.000000, bitrate: 12229 kb/s
Stream #0:0: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p, 720x
480 [SAR 8:9 DAR 4:3], 6000 kb/s, 29.97 fps, 29.97 tbr, 29.97 tbn, 59.94 tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, 8 channels, s16, 6144 kb/s
(1.2)
C:\Users\Administrator\Desktop\FFMpeg>1.2\ffprobe. exe "Y:\Video_LXF.lxf"
ffprobe version 1.2 Copyright (c) 2007-2013 the FFmpeg developers
built on Mar 28 2013 00:34:08 with gcc 4.8.0 (GCC)
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libg
sm --enable-libilbc --enable-libmp3lame --enable-libopencore-amrnb --enable-libo
pencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-li
bschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-lib
twolame --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enabl
e-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
libavutil 52. 18.100 / 52. 18.100
libavcodec 54. 92.100 / 54. 92.100
libavformat 54. 63.104 / 54. 63.104
libavdevice 54. 3.103 / 54. 3.103
libavfilter 3. 42.103 / 3. 42.103
libswscale 2. 2.100 / 2. 2.100
libswresample 0. 17.102 / 0. 17.102
libpostproc 52. 2.100 / 52. 2.100
480 [SAR 8:9 DAR 4:3], 6000 kb/s, 14.99 fps, 29.97 tbr, 29.97 tbn, 59.94 tbc
Stream #0:1: Audio: pcm_s16le_planar, 48000 Hz, 8 channels, s16p, 6144 kb/s
(2.0)
C:\Users\Administrator\Desktop\FFMpeg>2.0\ffprobe. exe "Y:\Video_LXF.lxf"
ffprobe version N-54835-g835eee8 Copyright (c) 2007-2013 the FFmpeg developers
built on Jul 20 2013 18:05:35 with gcc 4.7.3 (GCC)
le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp
e --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --ena
ble-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-l
ibopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libsp
eex --enable-libtheora --enable-libtwolame --enable-libvo-aacenc --enable-libvo-
amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --
libavutil 52. 40.100 / 52. 40.100
libavcodec 55. 18.102 / 55. 18.102
libavformat 55. 12.102 / 55. 12.102
libavdevice 55. 3.100 / 55. 3.100
libavfilter 3. 81.102 / 3. 81.102
libswscale 2. 4.100 / 2. 4.100
libpostproc 52. 3.100 / 52. 3.100
Any idea ?
Thanks,
Rajiv
Results 1 to 1 of 1
Video bit rate missing from FFProbe output
By rajivrp in forum Newbie / General discussionsReplies: 2Last Post: 30th Jul 2013, 10:53 -
What should slide show bit rate and frame rate be in video editor?
By johnharlin in forum Video ConversionReplies: 0Last Post: 11th Sep 2012, 22:00 -
MediaInfo: Frame Rate vs Original Frame Rate
By adalect in forum Video ConversionReplies: 1Last Post: 19th Aug 2012, 18:44 -
Changed frame rate avi to mp4, now time is incorrect...
By Lezleefeetsgoddess in forum Newbie / General discussionsReplies: 8Last Post: 24th May 2012, 14:05 -
Incorrect video duration/frame count in MKV/AVC
By crashbang in forum Video ConversionReplies: 2Last Post: 13th Oct 2008, 17:44
