Hello everyone,
I'm trying to convert dts audio file(that I already extracted from the mkv file) to ac3 audio file with 5.1 channels.
I tried several softwares like DaudioK but I'm getting an error massage "overflow".
can someone please tell me what can I do or which softwares can I use?
thanks a lot!!
Closed Thread
Try PopCorn MKV AudioConverter. It can convert the dts directly from the mkv to a mkv with ac3.
You're being very vague and not providing a lot of details for a guy who wants help.
Install MediaInfo and post what it says about your MKV file. I suspect that it doesn't have true DTS but maybe DTS-MA if Baldrick's suggestion didn't work for you.
mediainfo:
General
Unique ID : 234566152911413418647947674190588446748 (0xB077CC3B84BE1B89BB0731B5A8D0881C)
Complete name : D:\סרטים\Iron.Man.3.2013.1080p.BluRay.x264.DTS-HD.MA.7.1-HDWinG\Iron.Man.3.2013.1080p.BluRay.x264.DTS-HD.MA.7.1-HDWinG.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 14.4 GiB
Duration : 2h 10mn
Overall bit rate : 15.8 Mbps
Encoded date : UTC 2013-08-20 12:55:51
Writing application : mkvmerge v6.3.0 ('You can't stop me!') built on Jun 28 2013 20:09:41
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 10mn
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 132 r2323+704+51 d571b1c tMod [8-bit@4:2:0 X86_64]
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=11 / psy=1 / fade_compensate=0.00 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=36 / lookahead_threads=6 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=15.2000 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.20 / pb_ratio=1.20 / aq=4:0.85 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=0 / aq3=0
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 2h 10mn
Bit rate mode : Variable
Bit rate : Unknown / 1 509 Kbps
Channel count : 8 channels / 6 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : English
Default : Yes
Forced : No
Yep. Dts-ma. So just buy the dvd with ac3 audio instead. Reread our rules about downloading warez.
https://forum.videohelp.com/threads/72386-Forum-rules-Acceptable-Use-Policy-(AUP)?
eac3to: error converting 6.1 ch DTS -> AC3
By KushSmoka420 in forum AudioReplies: 5Last Post: 6th Mar 2012, 11:35 -
MKV files with Audio in DTS need to convert audio to AC3
By THEHNIC in forum AudioReplies: 5Last Post: 3rd Jun 2011, 09:17 -
Converting x.264 MKV w/ DTS to AVI w/ AC3 ?
By NotSoEasy in forum Video ConversionReplies: 6Last Post: 11th May 2010, 07:54 -
Converting LPCM , DTS and AC3
By Benjy in forum AudioReplies: 10Last Post: 8th May 2010, 06:20 -
Converting DTS to AC3
By badreligionhead in forum AudioReplies: 3Last Post: 18th Aug 2009, 01:07
