Downloaded Panic Room but it won't play so I presume I need a new codec. I have the Alpha 3.11, 4 and Divx 5 but no luck :roll: Please help!!
when in doubt drag it into VirtualDub -- that will produce a pop-up box telling you what codec you need.
your pal,
Stinky -
its probably the smr codec... i didnt really have an issue watching it because the version i got was on vcd
Webm Codec Advice Needed
By jg84 in forum Software PlayingReplies: 9Last Post: 20th Apr 2012, 20:10 -
Codec needed for particular .MOV file
By 6079 in forum Newbie / General discussionsReplies: 2Last Post: 14th Sep 2010, 13:45 -
Needed : A adpcm audio codec link plssssss x
By xJensbigproblemx in forum AudioReplies: 3Last Post: 30th Jun 2010, 01:41 -
Low CPU Intensive video codec needed
By fitch.j in forum Video ConversionReplies: 3Last Post: 16th Sep 2009, 05:40 -
strange codec needed
By bountylord in forum Software PlayingReplies: 1Last Post: 8th Mar 2008, 11:40
