I've just got my Hercules All In Wonder 7500 Radeon (last weekend) and am starting to get to grip with it, but am not sure of a few things.....
Is the best way to capture files intended for SVCD to capture at the highest quality possible with my system, them use something like TMPnge (or Nero) to convert to SVCD?
What's the difference between I, B & P frames? Duth it really matter....?!
Which is more important; higher res or higher bit rate?
For the final result, is AVI better than MPEG?
Thought I'd lump them together in one post....!
Thanks in advance....
You need to read through the guides on the left hand side of the page. Check below the HOW TO and check the CAPTURE section and see what is there. Many good guides will help you out.
Regards,
Savant -
Yeah, I have read those, but they don't explain about the frames (I only, I, B & P, which settings, etc), or which is more important; higher bit rate or higher res.....
Newbie bluetooth questions
By videohalp in forum Newbie / General discussionsReplies: 6Last Post: 28th Dec 2011, 05:37 -
newbie questions about ffmpegx
By Anoni in forum ffmpegX general discussionReplies: 2Last Post: 27th Mar 2011, 11:11 -
newbie x264fw questions
By anthell in forum Newbie / General discussionsReplies: 3Last Post: 10th May 2010, 05:33 -
Some newbie questions about sirius
By janeydoll in forum AudioReplies: 9Last Post: 10th Jun 2008, 02:19 -
Newbie Mplayer questions
By Maikeru-sama in forum Video ConversionReplies: 2Last Post: 21st Dec 2007, 14:51
