Hi all.
I've been reading through the forums but can't find exactly the info I need so was hoping someone here could help or point me in the right direction.
I work in the home theatre industry and would like to put together some of my own demonstration blurays. What I'm needing to do is to rip small portions of movies from the blurays to re-author and compile onto a disk with a small menu to flick between them. I have AnyDVD HD which is great for ripping an ISO to the hard drive but am a little lost on how I can select what I need to take off. I'm gathering that I won't be able to access the ISO directly to cut out what I need so will probably need to convert to a different format first? Obviously I want to keep the quality of the video and the DTS sound as high as possible.
I have no problem with the re-authoring side of things.
If anyone can shed some light on the most effective way of doing this I'd really appreciate the help.
Thanks guys!
				Results 1 to 9 of 9
	There is no easy method for it like dvdshrink for dvds.
 You can use tsmuxer to cut blu-ray m2ts or blu-ray playlists. But no preview so you must manually type in cut points.
 Tssniper might work on some blu-ray m2ts files.
 Some commercial editors might support blu-ray m2ts like videoredo h264 suite and solveigmm video splitter. But I doubt they support all audio codecs.
	In case you're not aware, there are a few really nice demo type discs out there at AVSForum. http://www.avsforum.com/t/1475769/demonstration-blu-ray-discs-independently-authored  Put NBC's Ed on Blu-ray! Put NBC's Ed on Blu-ray!
	Well I thought I had it working! I managed to get the video segment that I wanted but it didn't seem to do the DTS track, even though it says it's there? Obviously I'm doing something wrong somewhere?
	I've used TsMuxer to cut the segment of video I want. I'm selecting the h.264 file and the DTS-hd file. Not selecting anything else. I use the 'enable cutting' option to select the segment I want and turn off the chapters. Everything else I'm leaving as default cause I have no idea what they are.
 I'm then doing a Demux. Once that's done I'm remuxing back to a M2TS file. I tried just choosing M2TS mixing but that didn't work either.
 I tried to run the file on my PC and the PS3. But play the video fine but no audio. If I throw the file back into TsMuxer it says there is the DTS-HD audio track there?
 Any ideas or should I leave this stuff to experts?
  Alternative to dvdfab if it comes to 3D bluraysBy BeeJayF in forum Video ConversionReplies: 2Last Post: 16th Dec 2012, 08:39
  BluRays not playing right on N1By x22 in forum Blu-ray RippingReplies: 4Last Post: 16th Oct 2011, 15:43
  What do you use to play Blurays?By Dexx in forum Software PlayingReplies: 9Last Post: 24th Jan 2011, 17:27
  intel demos sandy bridge video transcoding engine...By deadrats in forum ComputerReplies: 8Last Post: 14th Sep 2010, 18:51
  Intro Demos to Vegas for a FriendBy solarblast in forum Newbie / General discussionsReplies: 2Last Post: 26th Oct 2008, 09:49
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
