Hello all
I have a little connection problem with my system... I've tried the logical thinking already, but I think it isn't my thing... make's me going
Anyway, this is the config :
1) The Monitor : Samsung LED XL2370: DVI - HDMI - audio out (jack) - SPDIF
2) The Speakers : Logitech Z323 (2 litttle speakers connected to a woofer) The woofer has a red/white "Auxiliary In" (not used now...)
3) The Desktop PC: VIA 7.1 on motherboard (VDECK Software) / SPDIF
Actual connection:
- 2 speakers to subwoofer -> PC audio out
- SPDIF monitor to SPDIF PC (?? use ?? In Win7 I don't see anything to configure this)
- HDMI to HDMI Graphics Board (GTX670)
I do have sound that comes out of the speakers, yet I have a feeling there's more to it than just this.
So, I hope one of you experts can help me out with this and tell me how to connect all this as it should.
PS: the monitor manual says that "This product won't make any sound when only the HDMI cable is connected without a speaker connected"
Thx for any advice/help/tip/solution
First of all, I'm assuming you are using the PC for video and audio out to your TV/Monitor and are using external PC speakers. No surround sound external amplifier and no DVD/DB external player.
The SPDIF output on the monitor is just a passthrough for the HDMI audio. It's for plugging into a external surround sound system. And if you are using a DVI>HDMI adapter, they usually don't include audio.
I doubt the PC speakers have digital/SPDIF inputs, so they won't work with SPDIF.
I'm not clear if you want to run SPDIF audio back into the PC for some reason, but PCs don't usually have that external input. It is likely on the motherboard but you would have to make a custom cable.
In your present configuration, if you are getting sound from you PC speakers of the video that's playing on the monitor, then that's likely all correct for your setup. If you want better sound, then use a surround sound amplifier and speakers. That's my present setup. I don't use the audio from the HDMI cable because I have a DVI>HDMI adapter at the PC that doesn't pass audio. I use the SPDIF output of the PC to go to my surround sound amplifier. Works great for PC and video audio.
I hope this isn't all more confusing for you.
And welcome to our forums.
I think all you need is a 3.5 male to male stereo cable. Something like this most likely http://www.amazon.com/Cables-Unlimited-AUD-1100-06-Stereo-Cable/dp/B000SE6IV8/ref=sr_1...m+male+to+male Your speakers don't have a spdif input. Which is why I suggested that cable. So for the over all connections. Hdmi out from video card>>>to monitor hdmi input. (you have your ati video card listed in your specs, so I assume that's what your using) Than just the 3.5mm cable output (line out) from the motherboard>>>to the 3.5 mm input on the speakers.
Last edited by Mr.Delusional; 30th Aug 2013 at 23:09. Reason: forgot to mention more information
How to connect PC to TV
By NonExistent God in forum DVB / IPTVReplies: 7Last Post: 4th Jul 2013, 13:27 -
connect pc to tv
By xbill in forum Newbie / General discussionsReplies: 3Last Post: 15th Feb 2012, 14:07 -
connect monitor far
By ecos in forum Newbie / General discussionsReplies: 9Last Post: 25th Jan 2011, 21:31 -
I want to connect my pc to a HDTV - need some help!
By j00n in forum DVB / IPTVReplies: 8Last Post: 10th Nov 2008, 16:02 -
Connect Laptop to TV
By Squid_uk in forum Newbie / General discussionsReplies: 9Last Post: 8th Sep 2008, 08:27
