    Jan 2011
    Canada
    'No Audio Decompressor Could be Found' is the message I get when clicking on the play button in Virtual Dub for an mp4 video. What should I do? Thanks.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Install ffdshow or ac3filter.
    Jan 2011
    Canada
    I downloaded and installed the AC3 filter. I restarted. It didn't work.
    I downloaded and installed ffdshow. I opened Audio Decoder Configuration. In the left pane, 'Codec' is highlighted. In the larger right pane is a list. 'AC3' has libavcodec. I see no mp4 listing.
    Dec 2005
    Canada
    If the mp4 uses aac audio, install the filter.
    https://www.videohelp.com/tools/AAC-ACM-Codec
    Jan 2011
    Canada
    That was it. Thank you.
