Results 31 to 40 of 40
Sorry, I meant to include fills screen top-bottom and left-right. I notice some cropping left and right if the HDMI setting is left in off. If it is set to super wide, the left and right are very fuzzy with horizontal lines. If set to pillar, I get a picture left to right that makes Basil Rathbone look like a 7' center in the NBA.
There is no Auto setting that I can find. Under video setup, there is TV display which has 3 options - 4:3 pan scan, 4:3 letterbox, 16:9 which is what I have it set to. Under HDMI, there is wide screen format section which has the three options mentioned above 4:3 pillar box, super wide, off (which is what I currently have it set to).
All of this piped into a Vizio 55" via HDMI cable. Vizio has Wide screen settings of wide, zoom, normal, stretch. I have it set to normal. -
Once you learn to see what is wrong it will bother you on every TV you watch for the rest of your life. You will be highly motivated to set it up correctly.
Sorry for going off topic but - how else are you supposed to watch a movie if its not on dvd or bluray? And it will be formatted the same if you stream instead.Originally Posted by sanlyn
I think it was mentioned elsewhere that unless you get a 2.35:1 tv you won't ever have it "exactly" as the producer envisioned without some black bars. And even then you'd have to have a tv for each format ever made to watch it without some borders.
The important thing for the home viewing is to not have it cropped. Any cropping drives me nuts. Thats why I buy my favorite movies on dvd or bluray and never try to preserve a cable showing of it.
More and more channels do show oar movies but the number of popup ads and the permanent big logos on screen never make it worth it to me.
Sorry for the offtopic.
And sanlyn I'm not trying to pick a fight or anything but in a home environment a studio dvd or bluray is the best possible presentation we can have at the moment. Until there is a 4k distribution pipeline this all we have. And even then 4k will still have the letterboxing issue.
What's most important to me is having it be widescreen and "enhanced for 16x9" tvs so that i don't have to use the zoom button on a FIXED letterboxed movie. Those are abominations and should be banned from the universe.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
And don't forget, even if you watch a movie in a decent theatre the screen is always masked to the proper AR.
Admittedly the ISF method is complicated and the calibration kits are pricey. But tweaks have been published that work for many brand-name LCD's. Glad it made an improvement.
Part of viewing movies as they were meant to be viewed is setting the right viewing environment. This includes darkening the room, sitting closer to the screen and properly calibrating your screen.
I "watch tv" with the lights on, but when I "watch a movie", the lights go off and the black bars melt into the darkness. Controlling the light during the day is usually difficult, but at least minimize the light directly behind and directly in front of the screen.
As children of the CRT era ("Don't sit too close, you'll ruin your eyes!"), we tend to sit too far away from the screen. Recommendations for a 55" screen vary from ~5.5' to 12'. If the actors in that CinemaScope movie are too small, sit closer or get a larger screen. When I first changed from a 40" to 55" screen, at first I thought it was too big for my ~9' viewing distance. Now I find moving 1-1 1/2" closer gives a better "movie" experience. My next purchase definitely be 65" or larger.
You've made a good step forward by tweaking your settings. Most HDTVs at their standard settings are overly bright and saturated to compensate for typically brightly light viewing environments. As sanlyn points out, true ISF calibration is very complex and not only requires specialized equipment, but a highly skilled professional. =$$$
The bottom line is that "watching movies" is far more complex than it ever was. Short of getting a 20' screen, dedicated viewing room, and 4K source, we have to make the best use of what's within our budget and viewing environment. If your goal is (as the majority of members of this forum are) to "view movies as they were meant to be viewed", that includes black bars side, top and bottom and tweaking your settings (environment and screen) to get the best out of what you have. -
Small black side bars when capturing
By encodingmonkey in forum Capturing and VCRReplies: 13Last Post: 26th Jul 2013, 23:56 -
CCextractor and TCM Movies
By BobT in forum SubtitleReplies: 11Last Post: 4th Jul 2012, 19:30 -
Need help getting rid of black bars on MP4 file
By Ch7lie in forum Newbie / General discussionsReplies: 2Last Post: 7th Jul 2010, 16:45 -
Getting rid of black bars with RipBot264
By tstein in forum Blu-ray RippingReplies: 4Last Post: 27th Feb 2010, 14:43 -
Playback has white bars on right side and jerky motion
By NumberNine in forum Newbie / General discussionsReplies: 1Last Post: 23rd Apr 2009, 02:42
