    Aug 2013
    Hi I am currently using subtitle edit 3.3.7 and I was wondering if there is any way I could add a foreign language (my language is not a common language and it's not in the options section) to the subtitle edit so that it would make subtitles in my language. Please give me in details of what to do as I am new to this. I appreciate your help.
    ps: I have searched far and wide on how to do this and I can't find ones that are helpful
    canada
    Open subtitle edit and choose spell check/get dictionary and select your language and click on download.
    Aug 2013
    that's just it, I can't find my language in the dictionary (I speak Burmese) is there any other way to add it to subtitle edit?
    it's just my grandfather doesn't speak English very well so I wanted to translate it for him
    canada
    As far as i know there's no Burmese dictionary for subtitle edit.
  5. Perhaps you could try here:
    http://my.duniakitab.com/ThanLwinSoft/ThanLwinSoft/Downloads/#OOoGr
    If you use Windows download
    thanlwinsoft-ooo-myanmar_0.1.0.30_windows_x86.oxt
    Change the extension .oxt to .zip and extract the files ny_MM.aff/my_MM.dic
    If you use an installer version af Subtitle Edit place thase files in
    C:\users\username\appdata\roaming\subtitle edit\Dictionaries
    If you use a portable version of Subtitle Edit place them in the Dictionary folder of where ever you installed Subbtitle Edit
    Aug 2013
    Hi thanks for the help (to the both of you ) and videobruger what do I do after that because I tried it and nothing happened. thanks in advance
  7. because I tried it and nothing happened
    I'm not sure what you expect to happen but once you installed the myanmar/burmese dictionary you should get a choice like this
    Aug 2013
    Hi thank you, I got the language but whenever I type something it still stays in English ( I am really sorry but you have to tell me step by step what to do because this is my very first time using this program ) again, I am really sorry but could you please be more clear. thank you
