Log File:
<8/23/2013 11:39:55 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 7
DVD Size: 8500/8500 MB (100%)
DVD Output Setup: MPEG2 File
DVD Label: DVD
DVD Menu: No Menu
Output Folder: C:\Users\Skyler\Desktop\Movies\Movie\Dvd
Delete Temp Assets Files: Yes
Delete Temp Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Video Source Filter: A2DSource
AVS Audio Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
Frame Adjust Strategy: 1
PAL SpeedUp: 0
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Tahoma 18pt (255,255,255)
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: D:\
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Unload ActiveMovie library: 0
Adjust ffdshow at runtime: 1
Save General Settings: 0
TITLE 1 SOURCE FILES
Video: C:\Users\Skyler\Desktop\Movies\Movie\Season 3\Clip 1.mp4
Info: AVC - 876 kbps - 720x404 - DAR 1.782 - 23.976 fps (CFR) - Progressive - 54:51 minutes - 78914 frames
Audio 1: C:\Users\Skyler\Desktop\Movies\Movie\Season 3\Clip 1.mp4
Info: AAC LC - 116 kbps - VBR - 2 ch - 48000 Hz - 54:51 minutes (83 ms delay)
[MediaInfoLib - v0.7.61]
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("C:\Users\Skyler\Desktop\Movies\Mov ie\Season 3\Clip 1.mp4", CacheFolder="C:\Users\Skyler\AppData\Local\Temp", FrameRate=23.976, VFR=false)
Audio = A2DAudioSource("C:\Users\Skyler\Desktop\Movies\Mov ie\Season 3Clip 1.mp4", CacheFolder="C:\Users\Skyler\AppData\Local\Temp")
Video = Video.ConvertToYV12()
Video = Video.Lanczos4Resize(720,480)
#Using DGPulldown/HCenc to upsize FPS
Audio = Audio.DelayAudio(0.083)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 1086.7 MB
Encoding Parameters: -ini "C:\Users\Skyler\AppData\Local\Temp\DVD_1_Title_01 _Clip 1.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\Skyler\AppData\Local\Temp\DVD_1_Title_01_ Clip_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Skyler\Videos\DVD_1_Title_01_Clip 1.m2v
*LOGFILE C:\Users\Skyler\AppData\Local\Temp\DVD_1_Title_01_ Clip 1.HCenc.log
*MAXBITRATE 9000
*BITRATE 2770
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*DBPATH C:\Users\Skyler\AppData\Local\Temp
*WAIT 2
<8/24/2013 12:18:29 AM>
END VIDEO ENCODING OPERATIONS
Video Source Filter: A2DSource (DirectShowSource)
Created File: C:\Users\Skyler\Videos\DVD_1_Title_01_Clip 1.m2v (1087.9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 2772 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 54:51 minutes - 78923 frames
START AUDIO ENCODING OPERATIONS (Track 1)
Wavi+Aften Parameters: "C:\Users\Skyler\AppData\Local\Temp\DVD_1_Title_01 _Clip 1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Skyler\Videos\DVD_1_Title_01_Clip 1.ac3"
<8/24/2013 12:20:31 AM>
WARNING! Errors found during Title 1 Audio Track 1 encoding.
Audio Channels are incorrect (6 vs 2)
Backup Audio encoding routine (FFmpeg Safe Mode) is starting ...
START FFMPEG (SAFE MODE) AUDIO ENCODING OPERATIONS (Track 1)
FFmpeg Parameters: -threads 4 -i "C:\Users\Skyler\Desktop\Movies\Movie\Season 3\Clip 1.mp4" -map 0:1 -y -vn -acodec ac3 -ar 48000 -ab 192k "C:\Users\Skyler\Videos\DVD_1_Title_01_Clip 1.ac3"
<8/24/2013 9:04:36 AM>
Process aborted during Title 1 AUDIO (Track 1) encoding operations.
For Audio issues troubleshooting see Help/FAQ/Audio section.
Log file created by AVStoDVD Release 2.7.1
I get that when the source is AAC and the Microsoft filter is being used.
Reset it to FFDSHOW and try again.
https://www.videohelp.com/tools/Preferred-Filter-Tweaker
[Attachment 19581 - Click to enlarge] -
If you set up FFDshow as I mentioned in the main thread, doesn't it solve the problem?
https://forum.videohelp.com/threads/277852-AVStoDVD-Support-Thread?p=2262263&viewfull=1#post2262263
No Audio when converting MKV to DVD using AVStoDVD?
By |StarscreaM| in forum Video ConversionReplies: 14Last Post: 8th Jan 2013, 23:57 -
Consistent Avisynth error in AVStoDVD
By kennedyb4 in forum Newbie / General discussionsReplies: 4Last Post: 4th Nov 2012, 11:41 -
When converting mp4 files using AVStoDVD no audio
By stem300 in forum Video ConversionReplies: 9Last Post: 2nd Jun 2012, 13:54 -
Error message when trying to encode one file using AVStoDVD Program
By spritely in forum Video ConversionReplies: 3Last Post: 25th May 2011, 11:52 -
Problems converting m2ts with subs in AVStoDVD
By eon_designs in forum Blu-ray RippingReplies: 6Last Post: 12th Dec 2009, 07:03
