Hi,
i am new to video conversion. I am xilisoft Video converter to convert the video and i am success with it. But the converted video is not working in my mobile which is Sony XPERIA E. But another video which is already HD is working. So i checked the difference using MediaInfo and found the that codec is is different. My converted video have codec is isom and the working video have mp42.
The information regarding the working video are the following (This is using media info)
General
Complete name : E:\Chubby Cheeks Rhyme with Lyrics and Actions - English Nurser.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 7.82 MiB
Duration : 1mn 47s
Overall bit rate : 612 Kbps
Encoded date : UTC 2013-04-14 21:10:04
Tagged date : UTC 2013-04-14 21:10:04
gsst : 0
gstd : 107275
gssd : BB64FFB48HH1374139207175207
gshh : r5---sn-ci5gup-h55e.c.youtube.com
Video
Format : AVC
Format profile : Baseline@L3.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 1mn 47s
Bit rate : 514 Kbps
Maximum bit rate : 1 327 Kbps
Width : 640 pixels
Height : 360 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.093
Stream size : 6.56 MiB (84%)
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1mn 47s
Bit rate mode : Variable
Bit rate : 96.0 Kbps
Maximum bit rate : 105 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 1.23 MiB (16%)
Title : IsoMedia File Produced by Google, 5-11-2011
Kindly help me to convert like this. I need any other converter or codec for this.
I tried using HD- h.264 video profile
hi,
i found that isom is not the issue. This is because of bit rate. I just trid with low bit rate and video size (480x320). Now video is working in my phone
How to convert 16:9 AVC to anamorphic MPEG-2 for DVD
By Xoanon in forum Video ConversionReplies: 26Last Post: 27th Aug 2012, 00:15 -
How to convert from mp4 to AVC, or AVCHD
By Frozegrew in forum Video ConversionReplies: 2Last Post: 17th Oct 2011, 18:28 -
!4 Q's? .flv avc virtualdub and convert hq ipod?
By angles in forum Video ConversionReplies: 4Last Post: 20th Aug 2010, 12:26 -
Is there a simple way to convert a letterboxed h264 video to avc mp4 psp?
By yoda313 in forum Video ConversionReplies: 2Last Post: 22nd Jul 2010, 19:13 -
Can't find a good program to convert .mov/.mp4/H.264/AVC watever video clip
By Nintendo Fan in forum Video ConversionReplies: 8Last Post: 21st Jan 2009, 19:28
