Hello
I picked up a used Dell external drive for a couple of quid hoping a adapter exist. Can anyone please tell me if there is such a thing?
Would i be able to remove the lead and replace with a USB cable?
http://oi40.tinypic.com/sbo411.jpg
				Results 1 to 11 of 11
	No. The cable in the picture in your link is a dual-plug USB cable. The external DVD drive requires power from 2 USB connections.
	Holy crap. I have NEVER seen that kind of connector before. I don't think I've ever seen a PC, not even a server, that has that kind of connector. I guess it's a Dell thing.
	I seem to recall a while back that the Dell unit was made by Toshiba. It would work with a laptop that has 2 USB input jacks mounted vertically. If a machine doesn't have two such inputs, you could get 2 individual USB extension lines (female A on one end, male A on the other end) and connect them to 2 USB inputs that are, say, side by side or in different locations. Both USB lines carry power, but only one (so I read a long time ago) carries data. You can still find portable DVD drives with dual USB connections, but those that I've seen lately have a split at the connecting end with an inch or two of wire leading to the two plugs; these still require both of the split ends to be connected to power the unit from USB inputs.
	I've had great luck with my "Dells of old" but they sure had their fair share of head-scratching-technology(?).
 Maybe Toshiba talked them into that for exclusivity or something.
	Thanks for the replies.
 It was worth a punt. I'll give it back to charity shop, and buy one off flebay.
	If the other end is mini-usb: The cable from an ASUS external might work.
 ;/ l ,[____], Its a Jeep thing,
 l---L---o||||||o- you wouldn't understand.
 (.)_) (.)_)-----)_) "Only In A Jeep"
	found this cheap wire which might help you out:
 http://www.newegg.com/Product/Product.aspx?Item=9SIA1PU0M68574
	Thanks again everyone for your help.
 mazinz Wrote:This looks great option mazinz, i have a trusty old 4x Nec rewriter in the cupboard.Re: Dell External Drive to USB Adapter - Does such a thing exist?
  ripping BD with BD ROM drive in external enclosure via USB 3.0By briansmccabe in forum Blu-ray RippingReplies: 5Last Post: 14th May 2013, 14:37
  External Hard Drive to TV USBBy codeseven in forum Newbie / General discussionsReplies: 6Last Post: 1st Nov 2011, 12:10
  Good durable portable external USB drive?By sdsumike619 in forum ComputerReplies: 3Last Post: 28th Sep 2009, 14:48
  Question about using external hard drive with USB DVD playerBy jimdagys in forum ComputerReplies: 2Last Post: 29th Jul 2009, 19:49
  Adapter for Dell Inspiron 6000 driveBy bevills1 in forum ComputerReplies: 4Last Post: 31st Oct 2008, 13:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
