I am trying to figure which of these is best, and all seem to say that they have their advantages over the other. Anyone out there who has had experience with at least one, I'd appreciate any info or opinions you could give me on difficulty or ease of use. Thanks
All three cards are quite good. We have a real-time round-up article on our website. At the end is a very comprehensive comparison of the different cards.
http://www.videoguys.com/RT3.html
You can also check out an excellent article by Charlie White
http://www.digitalvideoediting.com/2001/12_dec/reviews/cw_shootout.htm
To make the best recommendation, you need to let us know more what your final goals are and what kind of computer hardware you have for the job. If you want, give us a call 800 323-2325. We'll be more then happy to go over each card with you.
Gary
Videoguys.com
Problem capturing with canopus mpeg pro emr...
By dhugg in forum Capturing and VCRReplies: 4Last Post: 5th Jun 2010, 15:43 -
canopus advc 300 macbook pro
By petoo2 in forum Video ConversionReplies: 0Last Post: 9th Dec 2009, 20:29 -
Pinnacle DV500 Plus crashes on installation
By Dr.Rock in forum Capturing and VCRReplies: 2Last Post: 12th Feb 2009, 13:27 -
Using Canopus ADVC110 to Export to VHS from Final Cut Pro
By richisgame in forum MacReplies: 4Last Post: 14th Sep 2007, 20:18 -
Canopus Pro Coder Problem
By Heineken77 in forum Authoring (DVD)Replies: 10Last Post: 17th Jun 2007, 05:15
