The specs only allow 720x480 and 720x576 for SD resolutions, but an old post reminded me that the specs also don't mention DVD compatibility.
Since:
... that implies that the hardware in every BD player can play back those resolutions. The only question is whether the design allows the content to actually be played back from a Blu-ray formatted disc.
- every BD player nevertheless includes DVD playback
- DVD supports 704x480 and 704x576
If anyone is willing to test their player and report back, I've attached a small ISO that you can burn to BD-R or BD-RE. (It contains cropping test patterns that jagabo posted, so you can check your display system for that at the same time.)
Results 1 to 12 of 12
It doesn't really matter if some players can play it, 704x480 is not part of the Blu-ray spec so you should avoid using it. How happy would you be if you burned a bunch of discs that your current player can handle, but a few years from now when your player dies, you find your new player can't? Now you can't watch any of those discs.
Originally Posted by jagabo
You could just rip the disc and play it as a file with no issues.
But yes you should always format to the main specs and not any "side" specs that might or might not work in the long run.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
My current player is a PS3 that I bought second-hand and for the foreseeable future I would probably replace it with the same thing when it starts acting up. Otherwise, I like to think I would test in-store.
Regardless, I'm curious whether there are players out there now designed to reject 704x480. Thanks for checking, marlboro_man! -
The test plays on the Seiki BD660; no surprise there.
Let me know if you actually live long enough to see discs disappear. I've been hearing that one for a long time now. While they MAY disappear in America, and I won't even bet on that, I'd like to remind you that
America != rest of the world
VCDs are still as of this very day being commercially produced and that format has been superseded by at least THREE replacement formats (SVCD, DVD, BD - plus the dead HD-DVD and maybe even laserdisc if you want to argue for it) so I'm a bit skeptical of this "discs are going away" prediction that I've been hearing about.
Back on topic...
vaporeon800 - the usual caution applies that if you make discs that violate the standards, you can't complain when they don't work. jagabo covered the possible dangers in his post. -
Originally Posted by jman98
Anyway I guess what I was really getting at is that if you go with a digital file-based settop player than basically any resolution will work. Ok maybe not ANY resolution but you won't be fixed to a physical standard. It is much looser and potentially hackable to do what you want it to.
Hence the reason for suggesting a purely file based playback system (could be on disc or harddrive but point being "FILE" based not format based).Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I don't know if any of the standalone media players support raid mirroring directly. But if you use a NAS you can use mirroring on the NAS. That's what I do. Several players and computers in the house can all access files on the NAS.
Or you can use an old Windows computer as your NAS. -
So uh, my PS3 won't play 704x480 from BDMV.
I made a second test disc with 720x480, 704x480, and 352x480 each in MPEG-2 and AVC. The latter four files just display blackness for their duration.
I'm sure I had a good reason to start the thread before even testing the PS3... Or maybe I just assumed, since it accepts all sorts of resolutions during file playback and is pretty relaxed about GOP and other restrictions in DVD-Video mode. Indeed, it happily plays back the same three AVC streams when copied as .mp4 files via USB. (I didn't bother to mux the individual MPEG-2 files to see if they would also play.)
The Chinese player I mentioned played through the disc without issue.
3D Blu-ray player with iso and mkv support
By Vstreamy in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Aug 2013, 19:11 -
DOES NVIDIA-CUDA support the playback of 3D blu-ray disc?
By Stears555 in forum Software PlayingReplies: 3Last Post: 29th Jan 2013, 02:40 -
Burn mkv/whatever to blu ray disc playable on Vizio Blu ray player?
By Eric1987 in forum Authoring (Blu-ray)Replies: 3Last Post: 1st Dec 2012, 21:41 -
Recommendations Please, Blu-ray Player with USB HDD support
By Hollywood_12 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Mar 2012, 16:53 -
Blu-Ray player with HD mkv support?
By l0ngview0 in forum DVD & Blu-ray PlayersReplies: 25Last Post: 23rd Jan 2010, 22:37
