Good day!
I've got several .mpg files which are in 4:3 format but which look like a squeezed 16:9 (everybody is overly tall). Is there a way to 'unsqueeze' those files back into 16:9 without loss of quality? (i.e. permanently, not just by choosing a different aspect ration in VLC player).
Thanks in advance,
Boris.
Thanks guys, I've now tried both with the same result - if I just change the aspect ratio, the resulting file is indeed stretched but has thick black bars above and below (so that the overall file format is still 4:3). If I try to change the actual resolution (to 1024x576) the video become covered with blotchy green artifacts.
Any ideas would be very much appreciated. -
Try SD Copy hosted here:
http://paulmcgrath.net/download.php?view.8
I believe it was designed to change .mod file extension to .mpg files. But it works with .mpg and sets the 16:9 widescreen flag.
You can do a manual selection to choose individual files, or do a whole folder in one go.Last edited by mike20021969; 23rd Aug 2013 at 17:49.
