Query 1: To burn 2D Blu Ray movies to disc BD-50 DL, Blu Ray authoring is mandatory or not. I wanna watch it in my Samsung Blu ray player
Query 2: How to burn the 3D movie to BD-R DL disc? As .iso file or BDMV file structure. I need to watch in my Samsung 3D Blu Ray player.
I'm confused help me out!!!
Your Query 1 doesn't make any sense. DVD authoring doesn't have anything to do with bluray.
I mean Blu Ray disc Authoring is mandatory to play the disc in samsung Blu ray player (OR) simply can i burn the BD fiile structure to the disc so that it will play fine on my samsung blu ray player
What is your source, a commercial disc or something else?
After ripping a BD disc to hard drive, it would be ready to burn back to disc since it is already structured properly. -
My source file: I have downloaded the BD-50 quality Blu ray movies from online and stored in my External Hard drive. 2D movies i have in BD-File structure (BDMV format) 3D movies i have in .iso format.
I wanna burn that movies to Verbatim BD-R DL disc to watch in my Samsung 3D Blu Ray player.
Query 1: To burn 2D Blu Ray movies to disc BD-R DL, Blu ray authoring is mandatory or not.
I'm a newbie here pardon me for asking this simple question.Last edited by vishnuvardan19; 22nd Aug 2013 at 22:01.
Let's approach this from the other dirction. Your player needs a properly structured (authored) disk to play back 2d or 3d.
The folder structure is described halfway down this page:
https://www.videohelp.com/hd
If your existing files contain the proper structure all you have to do is burn them to disk. If they are simply free-range mpeg or avchd files, they have to be authored into the proper structure. -
Yes, i have them in Blu ray Disc folder structure.
BDMV
Playlist, clipinf, stream, auxdata, backup, index. bdmv, movie object.bdmv
Thanks a lot smrpix My query 1 is solved
Need solution for my query 2, how i need to burn 3D movies to BD-R DL disc? Directly burn .iso to disc through ImgBurn or extract the .iso and burn the Bluray disc folder structure BDMV + SSIF
I wanna view it in 3D effect using my Samsung 3D blu ray player.Last edited by vishnuvardan19; 22nd Aug 2013 at 23:14.
Please stop create new blu-ray 3d burning threads. Use this one. Reply to add new information.
Copying & ripping my blu ray movie then burning it onto a blank bluray disc
By chris_2012 in forum Authoring (Blu-ray)Replies: 18Last Post: 22nd Mar 2013, 10:43 -
VirtualDub + Quicktime Plugin - is FFDShow mandatory?
By oceanclub in forum Video ConversionReplies: 2Last Post: 10th Apr 2012, 19:30 -
Errors burning movie to BD-R using HP bd340i burner & PowerProducer softwar
By BDNov in forum Authoring (Blu-ray)Replies: 1Last Post: 15th Feb 2011, 09:34 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 18:04
