It looks like you remove the top to open it (or if you prefer the side with the curves edge); it's probably snapped in place. I like to use a razor blade to open those, start from a corner, slip it in the seem and pry the lid open. Use the full length of the blade not just the corner and it won't leave any marks.
The problem with eSATA is the cable, the specs say a SATA cable is 18" long and eSATA is 3', but the eSATA cable has better shielding. I've seen cheap kits that came with cables longer than 18" made with standard SATA wire. The eSATA connection on the box should only be a straight connection to the HDD's controller. If anything, the box controller should only pass the signal through to the drive. I've modded IDE enclosures this way, all that was needed was a USB bridge chipset with tri-state outputs, then I just added a 40 pin connector in parallel with the drive's.
Results 31 to 32 of 32
The top of the case was not snapped in place and could not be removed without breaking.
Is this good airflow to combat heat coming from video card?
By Stealth3si in forum ComputerReplies: 10Last Post: 1st Aug 2012, 15:20 -
Discontinuity threshold not working for windv
By Shmo in forum Newbie / General discussionsReplies: 3Last Post: 11th Oct 2011, 15:24 -
Huffy codec and field threshold
By TaranScorp in forum Capturing and VCRReplies: 7Last Post: 5th May 2011, 14:56 -
Remove Audio below threshold from video
By villumanati in forum EditingReplies: 2Last Post: 4th Nov 2008, 00:39 -
HDD swap! Faulty 'Funai HDR-B2735' vcr/hdd/dvdr ... use HDD in a JVC ???
By StuR in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Oct 2008, 13:38
