Hi people,
I have just re download a wonderful screen video capture (CamStudio).
But I want compress the video into H264. (or H265 if there are already stable final/stable release ?)
I have try x264vfw.2273kMod.x86_64 the install is successful but I don't find the codec listed inside CamStudio
My systm is Windows 7 64Bit
Thx people
Results 1 to 11 of 11
Selur, you seem have right encoding directly in H.264 seem have negative effect.
the video seem a little lagged. So which codec is the best for screen capture ? (I need video & audio)
Thx people. -
Try x264vfw at the ultrafast preset with CRF=0. If you don't have a version that supports presets use the ultrafast values from this post:
https://forum.videohelp.com/threads/347067-VirtualDub-H-264-Encoder-Speed?p=2169830&vie...=1#post2169830
The best solution is to capture with a fast lossless codec like UT Video Codec. Perform a slow encode with x264 later. -
Audio is usually so small compared to the video there's no reason to compress it. And most audio compressors don't work well in realtime. So I recommend you leave it uncompressed.
I have try the UT video codec,
but how read it inside VLC ? (possible ?) -
VLC doesn't support the UT Video Codec. Use a player that can use installed DirectShow codecs, like MPCHC. Even WMP.
Ut Video Codec Install Question
By soloalpinist in forum Newbie / General discussionsReplies: 7Last Post: 7th Nov 2013, 17:35 -
H264 video freeze on start in vlc 2.0.5 - Do i need to install a codec ?
By Atotaloss in forum Newbie / General discussionsReplies: 15Last Post: 15th Jan 2013, 14:08 -
VirtualDub Video Compression h264 encoder Not Shown
By darkw1zard in forum EditingReplies: 2Last Post: 18th Oct 2011, 15:28 -
[help] MKV with video codec H264 to mp4
By ageega in forum Video ConversionReplies: 2Last Post: 17th Sep 2010, 01:46 -
I'm looking for a good MP4-2/H264 video encoder which should NOT be based o
By clipperyoungamerica in forum Video ConversionReplies: 7Last Post: 19th Mar 2010, 17:54
