I am using a Sony Digital HD Videocassette Recorder (GV-HD700/1) and I'm trying to import video from MiniDV (SonyDVC) tapes that someone else recorded. When inserting the tape an error message appears telling me to "Change Tape To Correct Format". I have not been able to find a solution. The video was recorded 3 years ago (2010) on unknown cameras that I do not have access to. I think they might have been Sony cameras, but there is a possibility that they were Canons. Any help with this issue would be very much appreciated.
Well, what's recorded on the tape -- standard def DV or HDV? Whichever it is, you need to set playback of the Sony unit to that format.
I have tried it on DV and HDV settings, both were unsuccessful. I believe they were shot in HDV. Not 100% sure. The tapes were not bought overseas.
Okay, then. Is is possible they are DV format, recorded in LP speed? Could the audio setting be 12-bit instead of 16-bit? Is there any way you can contact the person who made the recordings to check what format and settings were used?
another possibility is they are HDV but are 720p60 and sonys can't handle that format. you'd need a jvc unit to capture from.
I trying look for info on Edit deck
By nemsese in forum Capturing and VCRReplies: 6Last Post: 27th Feb 2013, 16:08 -
Deck stain :-)
By MJA in forum Off topicReplies: 7Last Post: 16th May 2012, 11:51 -
Avid not seeing Mini-DV deck
By hlaycanson in forum Capturing and VCRReplies: 7Last Post: 8th Dec 2011, 21:24 -
Looking for mini dv deck
By CrippleCreek in forum MediaReplies: 0Last Post: 6th May 2011, 11:25 -
Recommendations for a Hi-8 deck?
By Big Chupa in forum Capturing and VCRReplies: 2Last Post: 11th Oct 2008, 17:20
