Is there a big difference between choosing NORMAL and HIGH QUALITY(SLOW) when you convert to SVCD?
Besides that high quality takes a few hours more than normal
Thank you for any help,
Scott![]()
Generally speaking, yes.
Even if there isn't a lot of motion during the clip, it affects the pixelation of certain areas.
The best thing is to try it out for yourself, using different video clips. If you're satisfied with normal quality, then go for it. It might not be a big difference to you, while it might be to others.
Good quality, normal sized video
By pcq in forum Video ConversionReplies: 17Last Post: 15th Aug 2011, 07:23 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 07:56 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33 -
Youtube HQ upload slow on normal quality
By seiun in forum Video Streaming DownloadingReplies: 2Last Post: 21st Sep 2008, 14:18 -
High definition video from camcorder onto normal DVD. Is it possible?
By VEINBERG in forum Newbie / General discussionsReplies: 7Last Post: 6th Mar 2008, 20:03
