What also seems a little odd, is while MediaInfo reports a variable frame rate, I'm pretty sure of you use the duration shown by MediaInfo and the number of frames to calculate the frame rate, it works out to be 23.976.
I opened the MP4 with VirtualDub and the Quicktime plugin, and VirtualDub reported the same frame rate as MediaInfo reports as the maximum.... 23.981fps.
When using the Directshow plugin, VirtualDub reports 23.974,
and when using the ffmpeg plugin, it reports 23.976.
Results 31 to 38 of 38
I see you're using HandBrake 0.9.9. Did they not ask you to try a nightly build on the HandBrake forums??
If there is a problem, then it's possible it might have been fixed in the latest HandBrake nightly build - there have been many since 0.9.9 was released. HandBrake-svn5740 is the current version at time of writing.
http://handbrake.fr/nightly.php -
Thanks everyone for testing this stuff out for me. I actually DID try the most recent 2 nightly builds and got the same results so I went back to the current release build. Maybe ripping with MakeMVK is causing the problem? I might try to just use AnyDVD and rip straight from the disc to see if I get a different result.
Nope but I will try that now. Was going with mp4 for max compatibility with iOS/other devices but let me try mkv!
Well would you look at that! Constant frame rate when using MKV! I guess I should have specified earlier on that I was outputting to .mp4 container but I didn't think it mattered! I think i'll try m4v next to see how that goes.
Edit: m4v also yielded VFR. So looks like I need to choose here if I want to encode to mkv or to mp4 with slight VFR...Last edited by thefinalprophecy; 24th Aug 2013 at 17:42.
Damn!! Now why didn't I think of trying that!?
There's definitely MP4 "oddness" I don't understand and which maybe isn't Handbrake's fault. I remuxed an AVI as an MP4 using MP4Box yesterday and a similar thing happened as it did when opening your encode with MPC-HC/ffdshow. The first frame became number one instead of zero and I couldn't even play the last frame. If I come across an MP4 and want to keep it, the first thing I do is remux it as an MKV.
computer restarts while encoding video with Handbrake. please help.
By christessmer in forum Video ConversionReplies: 26Last Post: 19th May 2022, 08:58 -
analog video to x264 - Handbrake vs. StaxRip vs. VideoToVideo
By TrackingError in forum Video ConversionReplies: 3Last Post: 17th Jun 2013, 12:06 -
After Encoding Handbrake gives Error and Output video doesn't work
By ConverterCrazy in forum Newbie / General discussionsReplies: 3Last Post: 12th Sep 2011, 09:36 -
Handbrake working with new version of x264
By levick in forum Video ConversionReplies: 7Last Post: 18th May 2010, 21:25 -
Alternative to handbrake.
By degarb in forum Video ConversionReplies: 6Last Post: 19th Nov 2009, 15:52
