I have just recently started to use staxrip and every time i lower the fps the video length increases and likewise when i increase the amount of fps the video length decreases. I would really appreciate it if i could get a solution to this problem.
What's the problem? That's what is supposed to happen when you change the framerate. What would you like to happen? That the video remain the same length? If so then you'll have to either remove unique frames if lowering the framerate, or add duplicate frames if increasing the framerate. Doing either will make the video play jerky. Removing frames (lowering the framerate) will make it play more jerky, though.
Doesn't StaxRip use AviSynth? If so it's using AssumeFPS to adjust the framerate. Maybe you want it to use ChangeFPS. If so, maybe there's a way to edit the AviSynth script. Don't know, never used it.
There's also a third choice but, in my opinion, it's horrible. That is to blend frames together to change the framerate. If that appeals to you, you want ConvertFPS.
Problem with StaxRip
By inject0r in forum Newbie / General discussionsReplies: 1Last Post: 27th Mar 2012, 15:14 -
Increasing fps in Staxrip encoding mkv files.
By Jayyflyy in forum Newbie / General discussionsReplies: 1Last Post: 10th Apr 2011, 14:05 -
Ripping Problem-Sub Title-StaxRip
By antonymaheshca in forum SubtitleReplies: 2Last Post: 6th Dec 2010, 05:44 -
StaxRip - oversize problem
By zacharias in forum Newbie / General discussionsReplies: 0Last Post: 7th Jul 2010, 13:10 -
Unknown/Old VSfilter version problem with Staxrip!!!
By Stb1990 in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2010, 23:39
