  1. Hey all,
    I have two MOV files that I need to edit with Magix Video Deluxe 2013 Plus. I cannot get them to open, though. I have tried VLC and Quicktime (both up to date). Quicktime, VLC, WMP and Magix do get audio, but no video.
    So I googled and figured I dont have the apropriate codec for the files, but even GSpot cant tell me what they are. I get
    "Rendering failed Following is the error reported by DirectShow. 0x80040265 [unknown]"
    as an error message, for both files.
    Handbrake as well as XMediaRecode can't handle the file. (Handbrake informs me I am lacking the right codec, XMediaRecode just kinda shuts down right after I try to recode.)
    I know that the files themselves arent corupt. I tested them on the Mac that I copied them from onto my external HD. They played with Quicktime just fine, from the original location as well as from my HD. Also, I have never had any problems with missing codecs so far. Like, seriously, I have not have a video NOT playing in, like, forever. Quicktime and VLC are up-to-date. I am using a Windows computer, however, so my guess is that that's somehow the root of the problem - switching between Mac and Windows.
    If anyone has any other ideas how to transform the videos into a format Magix can recognize or how to teach Magix how to deal with whatever current codec the files are in, I would be eternally grateful!
    Thanks in advance!!!
  2. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Use MediaInfo to get more information about the video. GSpot hasn't been updated in a while, and its support for video containers other than AVI and MPEG is rather limited. (On the OS X side, I recommend either VideoSpec or iMediaHUD to get information on a video file.)
    It's possible the videos were created using a Mac-only codec.
  3. Hey, thanks for the input. MediaInfo gave me this report:
    General
    Complete name : M:\clip-2013-05-16 19;01;39.mov
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 16.5 GiB
    Duration : 1h 58mn
    Overall bit rate : 20.0 Mbps
    Encoded date : UTC 2013-06-17 10:28:44
    Tagged date : UTC 2013-06-17 10:28:48
    Writing library : Apple QuickTime
    com.apple.proapps.originalFormat : AVCHD 1080i50
    com.apple.proapps.reel : CANON
    com.apple.proapps.clipID : 0000000079cf3800e39b67aa1b744ea796852ffb4798d43646 ac1c08f1e952b5628e6e3b367e3080eabe07aadab2814e1011 30472743d00b1b4a8828ae166b6831d0db77c041a7df14b237 d1456405b5c75cc153661c49a5
    com.apple.quicktime.creationdate : 2013-05-16T19:01:39+0200
    Video
    Format : AIC
    Codec ID : icod
    Codec ID/Info : Apple Intermediate Codec
    Duration : 1h 58mn
    Bit rate mode : Variable
    Bit rate : 18.5 Mbps
    Width : 960 pixels
    Height : 540 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 1.424
    Stream size : 15.2 GiB (92%)
    Title : Apple Video Mediensteuerung / Apple Alias-Datensteuerung
    Language : English
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : sowt
    Duration : 1h 58mn
    Bit rate mode : Constant
    Bit rate : 1 536 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 1.27 GiB (8%)
    Title : Apple Ton Mediensteuerung / Apple Alias-Datensteuerung
    Language : English
    Encoded date : UTC 2013-06-17 10:28:46
    Other
    Type : Time code
    Format : QuickTime TC
    Duration : 1h 58mn
    Time code of first frame : 00:00:00:00
    Time code settings : Striped
    Title : Zeitmarken-Mediensteuerung / Apple Alias-Datensteuerung
    Language : English
    Encoded date : UTC 2013-06-17 10:28:47
    When I click on the "Go to the web site of...." buttons, nothing happens.
    What next?
  4. GSpot is useless for MOV/MP4 files. Use MediaInfo instead. Oops, too late!
    https://en.wikipedia.org/wiki/Apple_Intermediate_Codec
    The Apple Intermediate Codec is available only on the Mac OS X platform and cannot be read on other platforms to date such as Windows or Linux.
  5. Gnahhh.... rawwwwrrrrr.... MEH!!!
    so what, no solution then? Could I recode it using the Mac that I got the files from?
    Surely, there has to be some kind of workaround... there always is.... right?
  6. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Yes, try to re-encode it using that Mac.
    (The Apple Intermediate Codec is, in fact, what I meant by "Mac-only codec." I just couldn't remember the name off the top of my head, this morning. )
  7. Alright, so it might not be so utterly hopeless afterall! Thanks, anyways, but I need to bother you again, as I my knowledge of Mac systems and software is very limited. What program would you suggest to recode from Mac? Also, should I recode into any specific format? I usually go with mpeg4, since the video is intended to be put on to a web site...
    (btw, dont you all just love Apple for making everything so easy and compatible? *gnarrr*)
  8. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Quicktime, perhaps. Or maybe even iMovie.
    I'm afraid I won't be of much help in that regard, since I don't do that much video work on my Mac. You might try asking this question in the Mac subforum here on VideoHelp.
    Just don't use the Apple Intermediate Codec, and you should be fine, for the most part, in going between Windows and OS X.
