I'm editing an OTA capture and part of it has audio off sync. I re-recorded that part with VLC and Mediainfo shows "Delay relative to video: 814ms". What free tools can fix this and keep the 6 channel audio? I tried Avidemux and it messes up the conversion with no sound except for a few seconds of choppy sound here and there, and the video stays on 1 frame etc. I don't know which muxing format settings to use though. Simply converting the clip with Any Video Converter fixed the sync but it only has 2 channel audio. VSDC Converter to avi H.264 keeps 6 channels but didn't fix the sync (Mediainfo now shows Delay relative to video: 460ms). I could try FFMPEG command line but used it just once before and need all the steps. Finally I tried converting to avi with VSDC Converter then fixing sync with Virtualdub and that worked. Steps
http://www.tutorialsroom.com/tutorials/details/vdub_adjust_sync.html
Also I'm using VSDC for editing. It lets me choose "no audio," "mono," or "stereo" (no 6 channel option) when starting a project but there is a "Channels: original" audio option in conversion. I chose that and AC3, 48000, 384 (video=H.264 avi) but Mediainfo shows 2 channels instead of 6 like the raw so it looks like VSDC doesn't support 6 channel? Strange since their converter supports it. I can use that converter to do the editing except for adding transitions. Am I doing something wrong or is there a free HD editor that keeps 6 channel audio?
Raw:
General
Complete name : C:\Users\Videos\Capture\Video\video.MPG
Format : MPEG-PS
File size : 5.32 GiB
Duration : 1h 5mn
Overall bit rate : 11.7 Mbps
Video
Format : MPEG Video
Commercial name : HDV 720p
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=30
Duration : 1h 5mn
Bit rate : 11.5 Mbps
Maximum bit rate : 11.2 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Active Format Description : Letterbox 16:9 image
Frame rate : 59.940 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.208
Time code of first frame : 06:05:25:00
Time code source : Group of pictures header
Stream size : 5.22 GiB (98%)
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Text #1
ID : 224 (0xE0)-CC1
Format : EIA-608
Muxing mode : A/53 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Bit rate mode : Constant
Stream size : 0.00 Byte (0%)
Text #2
Format : EIA-708
Text #3
Format : EIA-708
Results 1 to 1 of 1
Looking for Video Tool Converter/Splitter that has Audio Sync fixing option
By CyborgX333 in forum Newbie / General discussionsReplies: 60Last Post: 27th Oct 2012, 21:38 -
fixing 'out of sync' audio in video file
By Nonamer in forum AudioReplies: 10Last Post: 19th Feb 2011, 01:03 -
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 11:54 -
Fixing / Determining Audio Sync Issues With Only Some DVDs
By TheNut in forum DVD RippingReplies: 5Last Post: 12th Dec 2009, 17:47 -
Fixing audio sync issues when using GOTSent to convert MKV to MP4
By darrklight1138 in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2009, 06:56
